Help with El Gauges!!Please!!!
Old Mar 16, 2002
Alience's Avatar
Alience is an unknown quantity at this point
Hey.I bought El gauges (blue-green) for my 2002 civic lx automatic. I went to one guy he told me ,it will cost $90 to install it. well i said HELL NOOO. I tried to install them myself.I know how to put the gauges out but i dont know how to put el gauges on th old ones,it doesn't fit in And biggest problem for me is to connect wires. If anybody can help me reply.Thanks a lot guys .Nice website ,everybody helps eachother.[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Mar 16, 2002
pounds's Avatar
pounds is an unknown quantity at this point
$90 dollars isnt bad compared to what i was quoted....$150 from best buy!!!
so i just put em on myself and and had a local stereo shop wire it up....cost $15.....
Old Jun 26, 2002
HippyCivicEX012's Avatar
HippyCivicEX012 is an unknown quantity at this point
I paid 50 for my install
Old Jun 27, 2002
Krepoort's Avatar
Krepoort is an unknown quantity at this point
DIY Reverse Indiglo Gauges (with pics!) NOT 56K FRIENDLY
HTH
-Kre
Old Jun 28, 2002
escapeartist's Avatar
escapeartist is an unknown quantity at this point
Where did you get the EL gauges and where can I get a look at some (pics)?
Marc
Old Jun 28, 2002
snoopbag's Avatar
snoopbag is an unknown quantity at this point
I have the same gauges and they are very easy to install. If you can't follow the DIY hopefully this will help. The replacement gauges just fit right over the top of the factory gauges, you will need some glue or double-sided tape to hold them in place. Run the wires underneth the gauge cluster and attach the black ground wire to any metal suface. Then take the red wire from the new gauge faces and attach it to the red/black wire from the wire cluster with the blue clip ( you will need to expose the wires and then strip back the plastic covering on the red/black wire and then just attach the red wire form the gauges to the red/black wire and cover with electrical tape. Now test them before you put everything back together. You can put the switch anywhere you want I put mine in the coin tray, it is a good spot. Hope this helps.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
srtlat
Sep 17, 2015 11:02 PM
