making speedometer lighting blue?
Old Oct 15, 2006
gmag21's Avatar
gmag21 will become famous soon enoughgmag21 will become famous soon enough
Question making speedometer lighting blue?
can u change our speedometer from orange lighting to blue?
Old Oct 15, 2006
Maverick_1337's Avatar
Maverick_1337 will become famous soon enoughMaverick_1337 will become famous soon enough
yes you can and the climate control too.
Old Oct 15, 2006
burke420's Avatar
The World Is Yours!
i know that i think Gearbox did it, and there is somewhere a DIY...i think?!
Old Oct 15, 2006
just remove needles, clear the paint off the back of them with isopropyl alcohol, then clear the paint off the back of the gauge face with acetone and qtips carefully. dont spill any on the front. this will make everything see-through. then you can get some white glass paint and paint the bottom of the needles so you can see them. then all you do is wire in some blue leds and youre good. you can glue them to the bottom of the clear plastic shield.
Old Oct 15, 2006
SepulturaCivic's Avatar
SepulturaCivic has a spectacular aura aboutSepulturaCivic has a spectacular aura aboutSepulturaCivic has a spectacular aura about
Badass, i heard u cant control the dimness though after u put those LED's in right?
Old Oct 15, 2006
well its just a power and ground wire, you can tap it to dash light power that dims and then they will work with the dimmer. it just depends which wire you pick.when i did the dash leds, i wired them to work with the dimmer so its like stock.
Old Oct 16, 2006
gmag21's Avatar
thats soo sweet looking, is the thing that tells u ur miles still orange?
Old Oct 16, 2006
ya or you can change that too its just a bulb.
Old Oct 16, 2006
gmag21's Avatar
Question
where can i get the new blue bulbs, are they a certain size or somthing?
where can i find all this isopropyl alcohol,acetone, and white glass paint. Ace Hardware?
Old Oct 16, 2006
alcohol from walmart 90% proof, acetone hardware paint dept, glass paint from michaels crafts. these are not bulbs, they are LEDs, and you can find packs of em on ebay. id say get a 100 pack in case you mess up. i used about 40. and i wired around 4 of em in series and then sets in parallel. theres a led hookup faq in the lighting forum with daigrams.
Old Oct 16, 2006
gmag21's Avatar
kk ty
Old Oct 16, 2006
em2_dude05's Avatar
em2_dude05 is an unknown quantity at this point
thats sweet!!
Old Oct 16, 2006
gmag21's Avatar
Smile
i cant wait to do this
Old Oct 16, 2006
its fun, im starting another one ill prolly put up on ebay in blue. just take your time.
Old Oct 16, 2006
jester444's Avatar
Dain Bramaged.
jester444 is an unknown quantity at this point
I just did my Climate control in Red, and I'm about to do the cluster also. I took off the orange so now it's just white, but I got tired of it.
So groups of four in series? I was thinking maybe three in series to get it back down to a reasonable brightness, but I'll defer to your judgement. If you're not gonna do a DIY pictorial, I'll be happy to write one up when I do mine.
Jake
Old Oct 16, 2006
well it all depends on the leds. you can wire only so many in series until the total forward voltage exceeds the total input voltage from the alternator. so if you do red its around 2v and when you hook 7 together its around 14v then you need a bit more resistance. its always better to slightly underpower them and resist for 15v so they last a long time. it all depends on the leds color used. if you are just doing red, you can keep the stock bulbs and put red taillight repair tape behind the gauge face once its cleared. comes out great and you can put lil squares of paper on the hot spots to even out the lighting. but here is a very rough way to wire the leds. like i said it will vary and you will have to figure out which resistors to use.
actually this is the very first dash and cluster change i made, the cluster backlight was actually EL wire to match the cd player. its completely different now but ive always liked blue
and a few led hookup diagrams i made
Old Oct 17, 2006
gmag21's Avatar
Question
lol can i like buy that from you?
Old Oct 17, 2006
jester444's Avatar
Dain Bramaged.
Why would you want to? It's much more satisfying to make your own.
GB- so, if I were to use red LEDs, I would have an individual voltage of 2V each. Cause right now, I have each individual bulb with a resistor that's, I think, 6.2 ohms. Does that sound right? But If I were to wire up an array of seven LEDs in series, what strength resistor would I need, or how many? Or would I need one at all? Because the total voltage would be in the ballpark of 14V.
Sorry for the questions, I just wanna make sure I do this right. I can't remember all this stuff from Physics. Must have slept through that day.
Old Oct 17, 2006
you just use this and turn off your brain lol. but you need to know the info from the led manufacturer you bought from. forward voltage is typical 2-4V but its always different depending. red is around 1.9v and blue/white is around 4 but thats guessing. the led current is usually 20mA but it also varies. the total voltage i would say go 15v cause sometimes the alternator makes more than 14.4v and you dont wanna burn the led out early.
http://ourworld.compuserve.com/homep...Bowden/led.htm
Old Oct 17, 2006
jester444's Avatar
Dain Bramaged.
Thanks, man, that's going in the Favorites folder. Oh, I saw your LED information on importpassion.com Good job.
dragonsblood
Apr 27, 2015 12:28 PM
SpeedRacer
Nov 13, 2001 02:19 PM
wawacito
Nov 5, 2001 03:32 PM
