I CAN'T FIND THE D@*# HOLE!
Old Mar 16, 2002
Speedracer32's Avatar
Speedracer32 is an unknown quantity at this point
...IN THE FIREWALL.
I'M trying to wire my neons and LED's to the same switch but i can find the hold inthe firewall.
could someone show me if possible
thank you
Old Mar 16, 2002
pimpdakota's Avatar
pimpdakota is an unknown quantity at this point
Dude just follow your wiring harness back to the fire wall!! it'll prolly be on the driver side!!!
Old Mar 16, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
<< I CAN'T FIND THE D@*# HOLE! >>
[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Mar 16, 2002
i knew someone was going to say something
i still cant find it thou. i look in the DIY on pogi's civic but his is an auto
mine is a manual and i think the hole he used is the one my clutch cable is going thru.
correct me if wrong[IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Old Mar 16, 2002
importspd's Avatar
importspd is an unknown quantity at this point
yea, thgis happpened to me when i was hookin up a little led light, the only other grommet in the fire wall is on the passenger side. it is behind the glove box and comes out kinda near the top, it comes out right underneith that little clear container of liquid(i dont know what its called) but yea, thats the only other one, and let me tell you, it is a BIT** to get at. so have fun![IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Mar 16, 2002
CivicPunker17's Avatar
CivicPunker17 is an unknown quantity at this point
once u find it, tape the wire to a straight piece of hanger wire, at the top. then it pokes straight through the firewall and u just take the tape off, there it is, easy way to get the wire through.
Old Mar 16, 2002
Lrguy2's Avatar
Lrguy2 is an unknown quantity at this point
I was thinking girl troubles [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Mar 16, 2002
ph0ng's Avatar
ph0ng is an unknown quantity at this point
Yep, poke through the rubber think on the passenger side. you can see it as clear as day from the engine bay.
The easiest way I found to get through it is to jack up the car and reach up to it.
People run their 4 gague amp wire thru the same place... since there's plenty of room. And it's easy to hide the wire on the inside.
Good luck
Old Mar 16, 2002
oblivious9's Avatar
oblivious9 is an unknown quantity at this point
<< [i]
Sounds like a personal issue than a 'technical issue'
Find this hole [IMG]i/expressions/moon.gif[/IMG]
Old Mar 16, 2002
bobbyd's Avatar
bobbyd is an unknown quantity at this point
Passenger side at the bottom by the feet. There is a rubber grommet all you have to do is pull the carpet back and it is right there.
Old Mar 17, 2002
tsunamisplash's Avatar
tsunamisplash is an unknown quantity at this point
here you go.
remove the resonator.. and get your wires running thru this.
[IMG]/forums/themes/orbitz/paperclip.gif[/IMG] DSC00017a_copy.jpg (32 Kb)
97-DX-Lover
Jun 14, 2015 06:07 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
bluecoupe
Dec 20, 2001 07:12 PM
ademarco6
Nov 12, 2001 06:52 PM
doublins
Nov 11, 2001 07:01 PM
