Fuel injection fluid every 15k miles?
Old Mar 14, 2002
larocha66's Avatar
larocha66 is an unknown quantity at this point
hey everyone[IMG]i/expressions/beer_yum.gif[/IMG] I'm wondering if its highly recommended to put fuel injection fluid on my 2k1 civic. My mileage right now is at 18k. What other maintenance requirements(or recommendations) should I do besides oil change? Thanks for the advice[IMG]i/expressions/beer_yum.gif[/IMG]
Old Mar 14, 2002
randomguy's Avatar
randomguy is an unknown quantity at this point
If you are talking about fuel injector cleaner, I usually run some through every other service (7K miles). Maybe overkill, but it doesn't have any adverse effects. I always use Seafoam, which IMO is the only way to go. Check out Carquest - it comes in a metal can. Hope this helps.
Old Mar 14, 2002
larocha66's Avatar
Yes, I'm talking about the fuel injector cleaner How much does it cost to have it done by a mechanic?
Old Mar 14, 2002
Spider883's Avatar
9K Redline Owns U
all you do is put it in your gas tank when you fill up thats it
Old Mar 14, 2002
larocha66's Avatar
Sorry I don't really have time for knowing any engine tune ups. They charged me 50bucks and they were doing something weird when putting the fuel injector fluid. They removed the hose while the engine is running and they try to put the injector fluid little by little. Is this the right way to do it and does it require skills? It looks like I can do it myself... Whats up with that?? Did i get ripped off??
Old Mar 14, 2002
klam's Avatar
klam is an unknown quantity at this point
I just bought some STP, I'll see how that goes on my next service.
Old Mar 14, 2002
Pongster's Avatar
Pongster is an unknown quantity at this point
I use Chevron, which has Techron. So, it helps clean the fuel injection, or at least that's what it's supposed to do.
Old Mar 14, 2002
aferenz's Avatar
aferenz is an unknown quantity at this point
according to the manual useing additives such as fuel and oil cleaners is just a waste of money.
Old Mar 15, 2002
larocha66's Avatar
I want my 50bucks back!![IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
Old Mar 15, 2002
drbombay's Avatar
drbombay is an unknown quantity at this point
are you talking about the cleaner that hooks up to the fuel rail?
Old Mar 16, 2002
larocha66's Avatar
yah i think thats it@drbombay. you remove the hose from the pump while the engine is running. Then you gradually put the injector fluid so it gets sucked by the engine.
Old Mar 19, 2002
drbombay's Avatar
i think those cleaners are a lot better than the add to your gas type and actually worth the money. i almost bought the kit to diy. it's not a bad idea to do it, you have to decide how often. I might go 20-25k not every 15k. $50 sounds about right. a can of cleaner is $10, i think the kit is around $100
Old Mar 27, 2002
Spyder's Avatar
Spyder is an unknown quantity at this point
TRY OUT NOZ OCTANE BOOSTER THE ONE IN A BLACK BOTTLE, WITH 89 GRADE FUEL.IT CLEANS YOUR INJECTORS AND GIVES YOU A LITTTLE BOOST IN OCTANE. JUST FOLLOW THE INSTRUCTIONS. AT FIRST IT SCARED ME CAUSE IT DIDNT DO NOTHING BUT ABOUT AFTER 15-25 MILES LATER I WAS GOING DOWN THE FREEWAY AND FELT A HARD JERK AND MY RPM WENT UP BY 1000 RPM AND I STARTED BLOWING OUT ALOT OF WHITE SMOKE, BUT ABOUT 5 MILES LATER IT WENT AWAY, IT FELT DIFFERENT BUT NOT IN A BAD WAY.[IMG]i/expressions/beer_yum.gif[/IMG]
Old Mar 27, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
Old Mar 27, 2002
avenger's Avatar
avenger is an unknown quantity at this point
<< TRY OUT NOZ OCTANE BOOSTER THE ONE IN A BLACK BOTTLE, WITH 89 GRADE FUEL.IT CLEANS YOUR INJECTORS AND GIVES YOU A LITTTLE BOOST IN OCTANE. JUST FOLLOW THE INSTRUCTIONS. AT FIRST IT SCARED ME CAUSE IT DIDNT DO NOTHING BUT ABOUT AFTER 15-25 MILES LATER I WAS GOING DOWN THE FREEWAY AND FELT A HARD JERK AND MY RPM WENT UP BY 1000 RPM AND I STARTED BLOWING OUT ALOT OF WHITE SMOKE, BUT ABOUT 5 MILES LATER IT WENT AWAY, IT FELT DIFFERENT BUT NOT IN A BAD WAY. >>
[IMG]i/expressions/laugh2.gif[/IMG] [IMG]i/expressions/laugh2.gif[/IMG] [IMG]i/expressions/laugh2.gif[/IMG] [IMG]i/expressions/laugh2.gif[/IMG] [IMG]i/expressions/laugh2.gif[/IMG] [IMG]i/expressions/laugh2.gif[/IMG] [IMG]i/expressions/laugh2.gif[/IMG] [IMG]i/expressions/laugh2.gif[/IMG]
thats funny, in a bs kinda way
mattdoc
Mar 14, 2017 12:10 PM
ORskier
May 7, 2015 04:54 PM
bsmiley
Apr 27, 2015 01:27 PM
TopFuel
Jan 26, 2002 06:03 PM
TaiChi
Dec 17, 2001 09:09 PM
