Side mouldings or pinstriping!
Rep Power: 0 Side mouldings or pinstriping!
I saw some posts on removing the side mouldings. Seemed pretty easy, there're just glued on right; at least that's what everyone said. WRONG! If you own an '02 DX sedan do not remove the pinstriping from your doors. Yes they are glued on to some degree, but there also little plastic tabs in addition to the glue that fit into little holes in the door that further help keep the pinstriping in place. So if you don't like seeing holes in your doors, than don't pull off the mouldings. Good thing is that I think you can easily glue it back on if you did what I did (haven't glued it back on yet).
Now my question is, does anyone know how much it would cost to have the holes filled and painted professionally? Really, pinstriping is ugly. [IMG]i/expressions/face-icon-small-frown.gif[/IMG]
Eat poo & Choke ...I don't eat ham cuz my last name is HAM !!!!
Location: Palisades Park/Rutherford, New Jersey/in ur CORNHOLE, US
Rep Power: 291 u have to get it weldered shut and sand it and painteted too nmuch money
Rep Power: 0 sorry, if i ask a stupid question, so the 02 civic is the only model that have the hole after removing the moulding, right, cause i have a 01 civic, i wanted to remore that as well, will there be any problem, thx.
Rep Power: 0 If you want to remove the pinstriping...take a heat gun or even a hair dryer to it and peel it of with your fingernail. After that use an adhesive remover to take the sticky stuff off, then wash and wax, done.
If you want to remove the plastic molding piece that runs along the doors on a sedan then yes you have to have the holes filled, sanded, and paint matched to the car.
Rep Power: 0 Re: Side mouldings or pinstriping!
Originally posted by kFanghe
[B Seemed pretty easy, there're just glued on right; at least that's what everyone said. WRONG! [/B]
Civicforums Junkie
Rep Power: 424 Originally posted by AZ2K1Civic
you beat me to it!!
i did the pinstriping removal as stated...took like 20min with my heat-gun and i used goo-gone to get the excess adhesive residue off, then did the wash/wax...worked great!!
FYI: the coupes side moldings are 3M taped to the sides and the sedans are 3M tape AND clips
let the devil out
Rep Power: 363 I own a 02 sedan and had the dealership removethe pinstrip before I would drive it away . there should not be any small holes because all they did to mine was pull it off and buff it out
mjdiaz89
06-21-2016 09:26 PM
07-14-2015 03:39 PM
hondadriver95
07-13-2015 09:43 PM
ballmich
07-09-2015 11:59 AM
