problem after paintin caliper
Old Aug 7, 2006
army12bc's Avatar
army12bc will become famous soon enough
Exclamation problem after paintin caliper
i painted my calipers and the bolted them back and beld them now i have no brake pressure. what could be the problem? i had no problems before i did it now i can't drive my car. 2002 civic EX
Old Aug 7, 2006
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
pump the brake pedal a few times when your engine is off. If theres pressure, just remember to top off your brake fluid
Old Aug 7, 2006
em2kid's Avatar
em2kid is an unknown quantity at this point
Talking
do your brakes feel spungy if they do you need to bleed your brakes you most likely have air in your system i would recomend doing front and back start with your RR then LR then RF and LF after you bleed them check your level if you need to put fluid in it make sure its DOT 3
Old Aug 7, 2006
Diablo's Avatar
Diablo is an unknown quantity at this point
if you disconnected the lines to paint the calipers then you must bleed them make sure your brake fluid level is toped off.
Old Aug 7, 2006
solar's Avatar
solar is an unknown quantity at this point
Try gravity bleeding them, basically open both front bleeder valves and remove the cap to the master cylinder and keep adding brake fluid to the master cylinder until the fluid runs clean with no bubbles. Just make sure you don't let the master cylinder run dry, and don't pump the pedal until both valves are closed and the master cylinder cap is back on. I've used this method 100's of times when I turned wrenches for a living, the only down side is that you use a bit more fluid.
Old Aug 7, 2006
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
you should probably bleed them
Old Aug 7, 2006
Civicman1988's Avatar
pump the brake with the car off and see what happens when u put new brakes on u have to pump them. Make sure fluid is level if it needs more then put more also if u need to repeat the process over again to ake sure there is enough brake fluid in the cylinder
Old Aug 7, 2006
army12bc's Avatar
Retard
actually i'm just retarded i had the calipers put on backwards
Old Aug 7, 2006
tfnaaf's Avatar
BLDNPSI Mod
Dont feel bad ive seen some guys i work with that do brakes for a living put them on the wrong side with the bleeder at the botom
Old Aug 8, 2006
em2kid's Avatar
Talking
nice it happens...
Old Aug 8, 2006
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
^haha, yeah, dont worry, funny
Old Aug 9, 2006
streetglower's Avatar
dont feel bad, I went to replace a battery for a customer, removed the old one, set it down on the ground, look behind me to answer someones question, picked up the same battery and reinstalled it back in the car. didnt realize it untill I got back downstairs and looked at the new battery.
Old Aug 9, 2006
solar's Avatar
LOL
Once when I work for a Ford dealer, I gave a car a tune up, oil change, and a set of shocks only to find out I had the wrong car.
Old Aug 9, 2006
stinkypie's Avatar
A big, hairy Kentucky boy
stinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to allstinkypie is a name known to all
Originally Posted by solar
LOL
We had a mechanic do struts, shocks, transmission flush, coolant flush, and tune up on the wrong car once. We didn't realize he had the wrong car until after the car came back from detailing. Two white maximas, same year. One was due in to get all of that work done, the other one was just having a taillight assembly replaced.
Old Aug 9, 2006
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Holy grammar, Batman. You got about 6 sentences in there.
Old Aug 12, 2006
^bwahaha
Misfit2613
Brakes
26
Sep 1, 2018 05:02 PM
elitezdc5
May 26, 2015 05:46 PM
Flipg123
May 22, 2015 10:43 PM
domesticsnyper
Jan 8, 2002 11:29 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
