HVAC codes please help
Old Aug 1, 2006
bluestreak's Avatar
bluestreak is an unknown quantity at this point
Please help me find data on HVAC self diagnosis our cars are equiped with.
I cannot for the life of me find a list, chart, whatever which explains what the different codes for the information from the diagnosis. My car flashed nine times, or as I understand it, HVAC Diagnosis Trouble Code 9. I have searched all over the web, this site, and bought a haynes manuel today and it doesn't tell me ish. PLEASE help me, I really want to fix my AC.
Thanks, Duane
Someone...............................anyone...... .................help
Old Aug 1, 2006
solar's Avatar
solar is an unknown quantity at this point
What's wrong with your A/C? There's not a whole lot of info your computer will give you for your A/C. I've done some A/C work on 7th gens and EP3's and all I've used to diagnois the system was a set of guages and/or a volt/amp meter.
If the compressor isn't turning on, there's a good chance you're low on refrigerant (r-134a) which means you have a leak. But there's other things that can cause A/C problems, so elaborate and I'll see if I can help you.
Old Aug 2, 2006
bluestreak's Avatar
basically, last summer it wasn't cool at all, so I thought it needed recharging. My friend added only like 1/2 a pound or less and the compressor would only turn on sometimes when you turned the fan (ac) on. Now you can't ever hear the compressor come on. I checked the fuses and it seems fine? Please help - D
Old Aug 2, 2006
solar's Avatar
Sounds like you're low on refrigerant, a ½ lb of r-134a isn't much and if the system doesn't have enough refrigerant the compressor will not turn on or click on and off. The system has a "low pressure switch" that will detect that the system is low on r-134a and keep the compressor from turning on, keeping the comprssor from burning up. You need to take it to someone that has a set of A/C gauges and add the proper amount of r-134a. If it is low on r-134a, you have a leak, and it will keep leaking until the leak is repaired, how long the new refrigerant will last depends on the size of the leak.
Old Aug 2, 2006
bluestreak's Avatar
Thanks, I should just bring it somewhere, but when the self test was throwing a code, I figured I was half way there.....can't believe nobody has the codes
Old Aug 2, 2006
solar's Avatar
I really don't know what the codes could really tell you, I'm curious to what the code means also. A/C is pretty easy to diagnois with a set of gauges and knowledge of the system. Let me know if you find out what that code is.
Old Aug 2, 2006
bluestreak's Avatar
I called a friend who works at a Honda dealer and he isn't familiar w/ the code either? I have no idea but he said they're replacing alot of the "switcheS" on top of the compressor? Or it could be the compressor itself which is a pain in the *** to do I hear. I should've done this last fall or spring, it's my own fault i'm sweating my *** off now!
Old Aug 4, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
According to my manual nine light blinks (recirculation indication light) means a problem in the air mix control linkage, door or motor
Old Aug 4, 2006
bluestreak's Avatar
^you're the man! do you know anything else about the air mix control linkage? That sounds like it'd be expensive and I don't know where to begin or where to have it repaired?
Old Aug 5, 2006
scansel912's Avatar
Basically it says test the air control motor by basically giving it direct power to see if it runs.
If that works, you replace the old heater control panel with a new one and see if the problem persists.
If that doesn't work, you have to remove the whole control motor and replace it.
Old Aug 7, 2006
bluestreak's Avatar
you're talking the in dash climate control panel? Otherwise, the "whole control motor", where is it so I can test it? Thanks, sorry for the newb questions, but this is all new to me - D
Old Aug 7, 2006
solar's Avatar
If your compressor isn't turning on, I don't see how the air controller could have anything to do with it. ????? I'm really interested to see what your problem is.
Old Aug 7, 2006
solar's Avatar
EDIT: Duplicate post
Old Aug 7, 2006
bluestreak's Avatar
^ I'll keep you updated - D
Civic15
18
Sep 19, 2017 07:48 PM
MrOldskool
Aug 18, 2015 09:58 AM
jessica19699
Jul 29, 2015 05:51 AM
Green02civic
Jul 27, 2015 10:48 PM
m.colley
Jul 20, 2015 04:48 AM
