d16y8 swap problems
d16y8 swap problems
ok i got c ordnofs old d16y8 mani and put it on im using the d16y8 injectors and throttle body but my problem is im throwing a code for low tps voltage. ive checket the connections three times resauterd twice and its still there. I was wondering mabie if i need to switch the green and yellow wire i heard andyman say somthing about it. if you all need to see pics they are still in c ordnoffs thread. plz help im stuck with a crippled car untill i figure this out.
dude if they arent workin the way the are at the current wire setup just switch the green and yellow wires so they are green-yellow and yellow-green. im sure its different b.c mines auto and yers is a manual.
Ashho-san 7thgen Ninja
hmmm. ive been thinkin about do this myself, but i dont really know anything about intake manifolds adn such. do you have to use the y8 injectors? or will our stock ones work?
i had this before i sold it to 2k2 and no u will need to use y8 injectors or any cc injectors for the y8. the stock ones wont work cause i think either its to short or the size. if u are also gonna ask if rsx injectors will work no it wont only y8 stock injectors or injectors intended for the y8.
Im sure he did its one of the most important parts. By the way is it portmatched to the head.
Not to hijack but im gonna do mine with some intake manifold y8 application. And im going to make a flange for the d17 tb and replace the d16 one so almost everything will bolt up. Just to give you an idea of an easier way but slightly more expensive .
b20's come in crvs and ****. ive seen a few hatches with b20's and they scream. nice thing is the intake runners from the b20 intake mani and the stock flange from our POS d17 intake mani match pretty well. i wouldnt just go grab a b20 mani and start cuttin. i read an article in honda tuning before i did mine. the mag is in my car or id tell you exactly which issue it was.
those interested on the swap i dident get it to work i think the tps sensor was bad so im just gona get a tb adaptor plate made and welded on. it wile be a will before i atempt this again because school is starting up and i will have no time for it. http://www.7thgencivic.com/forums/im...icon_shrug.gif
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
SoyerOner
May 11, 2015 09:46 PM
Supramk3
May 11, 2015 07:55 PM
Chronic_issues
May 8, 2015 05:40 PM
