Driver side door panel..
Old Apr 4, 2006
misterpho7's Avatar
misterpho7 is just really nicemisterpho7 is just really nicemisterpho7 is just really nicemisterpho7 is just really nicemisterpho7 is just really nice
Okay long story short.. I was out to buy some food at a local fast food joint. Well waiting for my food to arrive I accidently dropped my debit card in the slit where the window goes in and out. I was wondering how I would get in there?
Old Apr 4, 2006
Colombian4Lyf's Avatar
Colombian4Lyf is an unknown quantity at this point
How the hell? You to take the panel off. There are screws by the handle you use to open and unlock the door. And another screw on the armrest where you grab and close the door. After you take the screw out, everything will pop off when you pull it off. You will be able to figure it out, Take your time
Old Apr 4, 2006
misterpho7's Avatar
Okay i Pulled out 3 screws, how do i go about pulling the whole piece off?
Old Apr 4, 2006
KINGCHILE's Avatar
KINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to all
Yeah Pop It Off. Make Sure All The Screws Are Out In The Handle Area
Old Apr 4, 2006
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
If I remember right, there are a total of 5 screws that you need to remove. Two by the door handle. Once you pop off the arm rest on on the bottom of the armrest and two more on the door itself behind the armrest. I recommend taking out the sail piece behind the mirror too, just makes it easier. From there start at the bottom, give a good hard tug to pop off the clips. Careful they are plastic and will break. Once the bottom is hanging freely, push the bottom of the door upwards to slide it off the window groove. It's really easy.
Best of luck especially postioning the lock again. That was a little tough my first few times.
Old Apr 5, 2006
djmota's Avatar
uhhhh... wouldn't it be easier to call your bank and have them send a replacement card.
Old Apr 5, 2006
misterpho7's Avatar
Well I was able to get my card, didn't knew there were 2 more screws behind the arm rest. I notice there was like a plastic bag covering over all the vents, what are those for?
Old Apr 9, 2006
aonyoung's Avatar
aonyoung is an unknown quantity at this point
got a question :
when i want to remove the front door trim panel to change my speaker, is the one that i marked big circle supposed to be all out ? is it one piece ?
thx...
Old Apr 12, 2006
misterpho7's Avatar
Originally Posted by aonyoung
got a question :
thx...
Yeah the whole door is one piece, make sure you push it up after pulling all the plastic clips.
Old Apr 12, 2006
DOHCtor's Avatar
DOHCtor is an unknown quantity at this point
^^^ what he said
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Youngciviboy
Jun 10, 2015 03:49 AM
Billybob1963
May 31, 2015 07:37 PM
ashlava71
May 16, 2015 12:54 PM
Macko
Exterior
Nov 19, 2001 10:34 PM
