need gauge cluster help
Old Mar 22, 2006
I'm in the process of retrofitting a 98 integra cluster with leds and it seems the idiot who installed indiglo gauges did so with super glue I was able to carefully peel them off but now there are big spots of glue on he FRONT of the stock gauges. Is there anyway to fix it without ruining the gauge faces even more?
also the "circuit board" seems to be a plastic sheet with some traces in it so can i even solder on it or is the whole thing gonna start burning.
Old Mar 25, 2006
luvvegas777's Avatar
banned from avatar useage
luvvegas777 is an unknown quantity at this point
try goo gone, are you replacing with new indiglo guages? don't know about the circuit board. good luck. are you going to run new wires to power your leds or use the stock wiring in the cluster? i would probably run my own wires to power leds.
Old Mar 26, 2006
zener_diode's Avatar
zener_diode is an unknown quantity at this point
the plastic circuit board is flex-circuit. it should handle the heat just don't leave
the soldering iron on it too long.
Old Mar 26, 2006
ya i just ran my own wires. thanks everyone. and the girl is getting me a new cluster so I'll just swap the faces with new ones
Old Mar 26, 2006
Civicman1988's Avatar
good luck let us now how it turned out
Old Mar 26, 2006
well the lighting turned out great, just waiting on the new faces to clear and put it all back. i'm very happy with the retrofit.
Old Mar 27, 2006
e04241's Avatar
e04241 is an unknown quantity at this point
wrong thread sorry
*****speedo needle would still work normally. the kmh or mph marking are just there for reference. whether u interchange the position, it will still run at
1M=1.6Km..
although the odometer will still run as MPH or KPH depending where the cluster came from (if that country uses km or miles for reading distance)
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
raymondxcho
Sep 29, 2015 09:00 PM
hondacivic0253
Sep 29, 2015 08:06 AM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
