How to disable SRS light with aftermarket steering wheel?
Old Mar 6, 2006
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
I just installed my aftermarket steering wheel that doesnt have an airbag and now my SRS light won't go off. I have tried resetting it, but that didnt help. What do I need to do to disable the light or just the SRS in general since I dont really need it for the passenger side? I dont want to simply remove the bulb from the cluster cause that is a permenant thing and I dont want to do that. So, my question is how do i get that bulb to not light up or how do I just disable the whole SRS system in general? Is there a fuse or something that I can just pull that will disable my SRS system so I dont have to worry about the light coming on?
Old Mar 6, 2006
2005SE
Guest
Posts: n/a
Man, I hope this is a race car, cuz drivin' with no airbags = UNSAFE. my .02
Old Mar 6, 2006
streetglower's Avatar
the only way to get that light to go out is either remove the bulb or put in your stock steering wheel with the airbag. no matter what, you arent protected wether the light is on or off because you have no airbag in the steering wheel. if you reallly want that light off, take 5 minutes and remove the cluster asembly and remove the bulb. it isnt a permanent thing, takes about 5 minutes to re-install the bulb.
Old Mar 6, 2006
Quantas's Avatar
I HEART KATIE
Quantas is an unknown quantity at this point
it only takes 5 to get at the back of the cluster??
Old Mar 6, 2006
skipbarber's Avatar
^less if youre experienced at it.
Old Mar 6, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Isnt it illegal to drive around with a aftermarket steering wheel *with out and air bag*if you car came equiped with a air bag?
Old Mar 6, 2006
NoMoreHonda's Avatar
Go Dodgers
NoMoreHonda is an unknown quantity at this point
my friend just installed a sparco steering wheel in his EP.. looks sick..
Old Mar 7, 2006
you remove the 2 screws at the top of the cluster, remove the bezel, then there are three or 4 more holding down the cluster, remove those and out comes the cluster.
Now not sure if it is illegal, but probably wont pass inspection.
Old Mar 7, 2006
j.lu's Avatar
j.lu is an unknown quantity at this point
as far as I know is not ilegal to drive a car without the airbags .Sell a car without airbags and don't tell the buyer that is ilegal.
Blazz
May 25, 2015 10:56 PM
cukaracha
May 16, 2015 02:11 PM
anddrrey
May 11, 2015 02:30 PM
jakeconnor
May 5, 2015 07:30 AM
JDQuikCivic
Nov 22, 2001 01:26 PM
