VTEC light
Old Mar 4, 2006
SilverVTEC's Avatar
SilverVTEC is an unknown quantity at this point
VTEC light
i have installed the VTEC light in my car(04 ex), and i know that vtec doesnt kick in till 4500...but my light will come on around 3k...so whats the deal?
Old Mar 4, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
u suuure?? do u hear it kick in at 4500? ur auto or manual?
Old Mar 4, 2006
acjones21's Avatar
4 cyclinders down, 4 to go.....
acjones21 is an unknown quantity at this point
there are three things that have to happen to get VTEC (oil pressure, RPM, throttle position). You are probably pulling a signal from too far up the chain (it's sending a signal when only 1 or 2 of the conditions are satisfied). VTEC lights are rice anyway.
Old Mar 4, 2006
SilverVTEC's Avatar
well what ever they are, what do you mean to far up the chain....it is about 2-3inches from the ECU...thats where it said to tapped into the line at. oh and i know that it depends on oil pressure, rpm, and TP...but it will come on at around 3k with me just easing into the gas...and i have a manuel.
Old Mar 4, 2006
CenZ's Avatar
PWIT
he means that it is turning the light on at the fist sign of vtec, not when it accually engages, those 3 things have to happen before opens a wire can not change the RPMs that vtec engages
Old Mar 4, 2006
SilverVTEC's Avatar
i know what he is saying, im just wondering if there is a way to get the light to come on when VTEC actually engages?
Old Mar 4, 2006
acjones21's Avatar
what the hell does it matter, you wanted a pretty light to flash on and that's what is happening.
Old Mar 4, 2006
RHCP0801's Avatar
waste of time, money and now i have a little led sitting on my car that i cant take out cause there will be a hole by my sig lighter, i installed it back in my rice days
Old Mar 4, 2006
SilverVTEC's Avatar
ok can someone...that has brains just answer my question instead of telling me its a waste of time and what not...thanks
Old Mar 4, 2006
acjones21's Avatar
OK, here it is. Run a 0 gauge wire from the positive battery terminal to your gauge cluster. Run this wire to a LED and ground it. Start your car up and shout "VTEC".
Old Mar 5, 2006
R3DL1N3's Avatar
i've got a vtec light and my vtec kicks in at 3000rpm. i've got an 02 ex. and yes i regret putting mine in for the same reason rhcp said.
Old Mar 5, 2006
just because the light comes on at 3k, doesn't mean the vtec solenoid switches to hi cam. there is more than one signal needed to do that like mentioned above. and vtec comes on around 4500 rpm when the gas is floored and car is at operating temp.
Old Mar 5, 2006
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
read this and yah know that we have 2 vtec point.
http://www.leecao.com/honda/vtec/3stagevtec.html
Old Mar 5, 2006
zachgeyer's Avatar
weredo u get this light
Old Mar 5, 2006
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
my god guys, if the guy wanted to be flamed 24\7 he'd buy an srt-4, he had a simple question now answer it instead of telling him how wrong what HE wants to do to HIS car is, only thing i can think of is try tapping into one of the other 2 lines instead of what you currently tapped into, i wish i could help more, but i dont have a ex....look in the diy section as well, i think theres a diy for it in there.
Old Mar 5, 2006
SilverVTEC's Avatar
thanks for the input guys...on the VAFC isnt there a light that comes on when vtec kicks in? and so in our cars vtec only works at FULL throttle...along with the oil pressure, rpm, and temp? i was just suprised that it only works at full throttle.
Old Mar 5, 2006
yup its been tested with a data logger. the 12v signal to open the solenoid wont happen without all those conditions being met.
Old Mar 5, 2006
acjones21's Avatar
it's only purpose is to save fuel at full throttle, so it only kicks in at full throttle. vtec-e isn't for power. it could also be argued that i-vtec (found in the K-series) is only for fuel economy too, since it allows better response out of a smaller engine (one cam down low for torque and one up high for HP). smaller displacement USUALLY equals better fuel economy. Honda tried to carry this philosophy over to its "performance" engines and, imho, failed b/c the NSX engine and the S2000 engine offer good HP/L, but pretty miserable fuel economy and not many liters (so not much HP). The vette engine has better HP, Torque, fuel economy, and weighs significantly less than an NSX engine. I know that some people will reply about NA horsepower being best, and I agree. many vette people are getting 600whp on a stock LS1 block NA and (and torque peaks at 3000rpms, not like in a supra motor)
when you use the C5R race block (akin to the F20C block b.c it was built from the ground up for no compromise performance) all bets are off and you can build 8000+ RPM 430 cubic inch world beaters. gas mileage will suffer in these applications, but it will in a fully built ITB F20C as well.
Old Mar 5, 2006
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
hahah....srt-4...haha. they'd hand us our asses even if we had 2 d17's in our cars.
Old Mar 7, 2006
hockeyc574's Avatar
hockeyc574 is an unknown quantity at this point
VTEC light would be nice
Old Mar 7, 2006
RHCP0801's Avatar
its pointless and stupid
Old Mar 7, 2006
SilverVTEC's Avatar
ok its pointless and stupid...hmmm you have stuff done to your car, such as billet aluminum lower grille, sohc vtec sticker which could be labeled as pointless and stupid...but i didnt say that...so why dont you keep your comments to your self. this is addressed to rhcp0801.
Old Mar 7, 2006
blackBDMcivicLX's Avatar
For every sprinkle I find, I shall kill you.
blackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant futureblackBDMcivicLX has a brilliant future
pwned
Old Mar 7, 2006
booba5185's Avatar
someone call the fire dept cuz he just got burned!
Old Mar 7, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
rhcp0801 = lol
Old Mar 7, 2006
streetglower's Avatar
alright I am going to end this right now since everyone is getting off topic and starting to flame each other.
tadr88
Jun 8, 2015 12:28 AM
01civyv3
Jun 2, 2015 05:21 AM
MiniMi
May 27, 2015 01:57 PM
LionSpratt
Apr 26, 2015 01:02 PM
injencivic
Nov 9, 2007 02:31 PM
