CEL out of the blue...
Old Feb 20, 2006
gh0st's Avatar
TAQUITOS!!!!
So I drive my school to car this morning and park it...nothing wrong with it on the drive over. About 7 hours later, I come back and start up the car letting it warm up before I head home. About 15 seconds into the car starting, the engine light comes on...great right...
I call up the stealership to see how much to check the code is $99 and an appointment. no thanks.
Thing is, I haven't done any engine mods. Oil change at regular intervals, car has 78XXXK but with the tires messing up the speedo...it's less than that...
I have no idea why the CEL came on. I did a quick search to find anything, and I didn't really see much. My friend said to check all the hoses and what not and nothing seems out of place. I havne't even touched the engine as far as modding.
Any Ideas?
Cliffs: CEL came on after school. No engine mods. Plugs seem fine. 78K miles.
Old Feb 20, 2006
mrDFWmechanic's Avatar
do you live close to an autozone ?? take it there they'll check it for free
Old Feb 20, 2006
dj02's Avatar
could be a number of things. take it to a parts store like autozone and have them check the code and then you will know what it is.
Old Feb 20, 2006
aznrocka's Avatar
aznrocka is an unknown quantity at this point
yeah, if u have an autozone by you go there and have them check it out...also try checking hoses and caps and stuff...my friend had his gas cap not tight and the check engine light came on.
Old Feb 20, 2006
NOgoEM2's Avatar
-jdmWANNABE-
NOgoEM2 is an unknown quantity at this point
is your gas cap loose? might sound really stupid but mine came on one time because my gas cap was loose and i didnt figure it out until I talked with a mechanic from Honda...
Old Feb 20, 2006
buy the ebay code scanner for $30. mine has paid for itself 10 times over. just plug in and read the code and look it up in the book they give.
Old Feb 20, 2006
Christian Calim's Avatar
Christian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to beholdChristian Calim is a splendid one to behold
i would just reset the car and see if it still goes on after that. i forget to reset my car after a couple oil changes and cel pops up and after reseting it goes away. other wise if it still comes on go to autozone.
Old Feb 20, 2006
LADIESMAN's Avatar
LADIESMAN is an unknown quantity at this point
ya definately check the reset first i've had it happen couple times after an oil change.
Old Feb 20, 2006
streetglower's Avatar
Any Ideas?
just cause you havent done any mods or touched your car doesnt mean that parts wont fail. you have tons of electrical items that work together will the ECU to run your vehicle and at any given time one of those parts may fail internally. sometimes the car will still run fine, other times it will start running like ****. Now you could have something as simple as a bad IAT sensor or bad MAP sensor or O2 sensor, or could be a bad cat converter, EGR valve, or a problem internally with the tranny (yes I said tranny because you have tranny codes) etc... it could be anything. once you find out what the code is, then you can go from there. Dont worry about it though, it isnt a big deal.
Old Feb 21, 2006
gh0st's Avatar
TAQUITOS!!!!
so i reset the ecu, and it went away......thanks for the input guys. first time it's come on on me, so i got freaked cuz i thought i broke my car :P.
Old Feb 21, 2006
dj02's Avatar
awesome
-closed-
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Luluharp
Sep 27, 2015 11:56 AM
Mannimarco
Sep 7, 2015 10:01 PM
dantheman42
Sep 4, 2015 01:10 PM
jpat21
Sep 3, 2015 11:32 PM
