built auto trans
I'd say it's possible to build up the Auto. First the weak carriers have to be swapped with a better part. Then some of the springs in the valve body need to be modified to increase clutch pressure for less slippage. Something like a towing kit for autos. It would help, but all the weak metal parts would need to be identified and "fixed". Imagine if they used titanium in the tranny, it would last half a million miles. $$$$$$$ though.
hmm not sure its about the cost of getting the trans fixed so prolly around $1.5-2k. They have to take the tranny apart. if you can believe it, nobody where i live knows how to take it apart.
THE LONE STAR STATE
Originally Posted by rhcp0801
you can overhaul the tranny to make it handle more power, eyeseeyou did that with his turbo auto civic
texascivic2k1
Wanna see a donkey show?
Just a converter is not gonna make it bad *** you will need a new hardened sprag set and stronger guts. I am sure tci makes some thing but i do not trust them I have had one of there built street strip trannys completly blow up with less hp than they reccomended it for and about 1.5 years/less than 50k miles.
Btw just adding a shift kit will harm your tranny it makes it shift way harder and wears out your clutch sets faster. A ported valve body will get you a firmer shift but not so firm that you'll break some thing.
Do youself a favor and read this article, pay special attention to the part about Overlap;
Shift Kit explained
Though I don't know the in's and out's of the Civic tranny, I would assume since it's an auto it's basic functioning is similar.
I have a pretty high pressure shift kit in my Coronet, a B&M Stage II. It's more of a street/strip setup. It up's the pressure so that the shift is immediate, neck snapping and tire chirping, even under normal driving. I'm sure over time this setup is harder on the car than stock or a stage I because it's extra aggressive.
Jordan
Originally Posted by 65Coronet440
I'm a novice with the new-age auto's but older model tranny's last longer with a shift kit. Less slippage between shifts = longer clutch life.
Shift Kit explained
Jordan
Shift Kit explained
Jordan
As that builder states there are many forms of shift kits. In my experience just putting a shift kit in an oem tranny will wear out the bands and clutches fast. I had a jack *** buddy in high school that did it to a chevy to where it shifted so very hard even normal driving.......well he had to take it back apart soon after. As in the article is what they did to my small c-6. They ported my valve body which made a nice shift but it would never chirp it would just shift nice thats why I recommend it. I would go as far to say if I had a shift kit in it I would have parked it sooner. But from what I have read in his article I prolly would still be driving my truck.....but its not the case with my tci garbage. Thats why I do not want any body to have my luck. A mildly built 351w with world heads small trw cam/ trw 30 pistons/trw bearings. Blew that small c-6 up so bad the oil is grey and full of pretty sparkles. Btw I have a local racing tranny builder that also puts alot of shame on the tci tranny he knows his crap if you ask him he will tell you stay away. But you may be right not all trannys are the same besides it is an upgrade so I guess its better than whats there. I just would like the guy who built his honda tranny to give us an longevity update in a year or 2.
Edit btw nice granny four speed lol I had one in one of my ford(s) 4x4 I could climb a mountain with it.
May 4, 2016 07:14 AM
mrohitredd
Aug 12, 2015 11:36 AM
Dangerousjordan
Jul 27, 2015 03:43 PM
Jul 12, 2015 11:54 AM
