new head bolts????
new head bolts????
i am thinking bout buying a ported and polished head....i was wondering when i swap the heads do i have to get new head bolts or can i use the same ones? also if i have to get new ones do they have to be arp. cause im not boosted or spraying just n/a....
new bolts anytime you swap the head. oem is fine for na, but dont have the head milled or the gasket will blow. oh yea you also need all new gaskets when swapping the head.
Wanna see a donkey show?
Milling should not blow a gasket but you should be careful. Old skool datsun heads only have a .008 of max shaving. But yes every time you pull the head you should use new bolts. They stretch and get brittle and old bolts may not give you a proper tq reading when trying to retighten them.
Originally Posted by djmota
from personal experience I swapped my head with a new gasket and used head bolts on a milled head. No problems here..
I also spray nitrous on this engine.
Its not that you can not use them its just not wise to. It also depends on how long they where on for. For instance when building my 4cyl race motor i opted for new bolts cause the old ones had over 200k miles on them. And its just insurance for what could happen. Would it be crappy if you blew a motor/ gasket just by a simple bolt. I say if you are spending money on the top end do it right.....why do the same thing twice and risk some thing of way more value. Kinda like me the jackass who decided to run a stock oil pump on an engine that had drilled rod oil passageways. Now I have to pull it all apart and replace the spun bearing. Simple fix of oil pump= 80 bucks......now I have to shell out $$$$$ to fix it.
welll mine has bout 100k miles on it...so does arp make head bolts for the
d17a2 also would like a napa brand head gasket be sufficent for a shaved head or should i get a better one...or is there a better brand for our cars
I need TP for my bunghole
old97civic
Jul 9, 2015 12:19 PM
robbie374
Jul 7, 2015 02:56 AM
PierrePierre
Jun 17, 2015 06:22 PM
Jun 2, 2015 11:54 AM
