Rear Suspension in 2002 vs. 2001
Old Feb 15, 2002
3rdcivic's Avatar
3rdcivic is an unknown quantity at this point
Has anyone ridden in stock form 01 and 02's? Is there an improvement in the rear suspension for the 02's?
Thanks for any feedback.
Terry
Old Feb 15, 2002
VNlilMAN's Avatar
The Standard One
i'm not exactly sure what they changed but yes it did change... i had a 01 n it got totalled n now i have an 02. the 01's real bouncy n the 02 isn't.
Old Feb 15, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
Stiffer shocks I think.
Old Feb 15, 2002
VNlilMAN's Avatar
The Standard One
that would mean less chance of them blowing with a 2" drop right?
Old Feb 16, 2002
civic2k2lx's Avatar
civic2k2lx is an unknown quantity at this point
also, i could be wrong
but the 2002 got a front sway bar and the 2001 dont have it
Old Feb 16, 2002
<< also, i could be wrong
really??
Old Feb 16, 2002
Dakker's Avatar
Giggity Giggity
Dakker is an unknown quantity at this point
i have an 02, where is this strut bar? hehe
Old Feb 16, 2002
civic2k2lx's Avatar
not strut bar, sway bar
they r different
look under your hood, near the back, right on top of the axle, there should be a gold color bar running parallel to your axle
u see it?
or it might be a stabilezer bar or something like that
all the same
Old Feb 16, 2002
VNlilMAN's Avatar
The Standard One
what does a sway bar have to do with the car bouncing up n down? its has to be either shocks or springs but which one is it?
Old Feb 16, 2002
blouisgod's Avatar
Life Begins > 6800rpms
i hear the 02 has stiffer shocks AND stiffer spring rates
Old Feb 20, 2002
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
Do you think the '01 springs and shocks can be replaced with the '02 ones directly ?? The '01 ride sucks !!!
Old Feb 20, 2002
SQCivic's Avatar
SQCivic is an unknown quantity at this point
That was my question as well. Can any of the suspension improvements on the 2002 be transferred to the 2001?
Old Feb 20, 2002
Seveneighty's Avatar
Seveneighty is an unknown quantity at this point
Damn, if you're trying to get your 2001 to be more like the 2002, I can't imagine how bad the 2001 ride is..
I thought my 2002 was a very uncomfortable ride!
Old Feb 20, 2002
fogbow's Avatar
fogbow is an unknown quantity at this point
<< That was my question as well. Can any of the suspension improvements on the 2002 be transferred to the 2001? >>
I have a 2k2...
I believe they can. Most of the stuff for the 2k1's fit the 2k2 and sameway around. So I really don't see why not.
Far as with the sway bar, I was changing my oil a few weeks back and it brough it to my mind that I thought I saw a sway bar, but it wasn't a gold bar...I guess I'd have to run outside and check under my car
Old Feb 20, 2002
VNlilMAN's Avatar
The Standard One
if it is, anyone wanna buy my stock springs i might get eibach sportlines soon.
Old Feb 21, 2002
3rdcivic's Avatar
My 2001 EX Coupe has a front sway-bar and a rear sway-bar from the factory. I don't know about other models though.
Old Feb 21, 2002
NitehawkVTEC's Avatar
NitehawkVTEC is an unknown quantity at this point
I thought EX/Si's had front Sway bars and rear sway bars. My 2k1 Si has front and rear.
Old Feb 21, 2002
anibal's Avatar
anibal is an unknown quantity at this point
Every 2k1 civic has a 25.4 mm front sway bar and the EX model has a 12.0mm rear sway bar. For 2k2 models they added the rear bar to the LX and HX models. As for the swapping of springs and shocks, I think it's possible, they've changed the damper and spring rates, I don't think they've changed the design.[IMG]i/expressions/face-icon-small-cool.gif[/IMG]
Old Feb 22, 2002
3rdcivic's Avatar
Actually for the front suspension, they replaced that crappy plastic strut bearing with a metal/ball-bearing assembly. Thus, hopefully those of us with lowered cars won't experience that popping noise when we turn our wheels.
I've ordered new strut bearings and upper mounts from the 2k2 to go on my 2k1. I have Ground Controls so I had to order the upper spring perch from GC to fit the 2k2 strut bearing.
Now, all I need to do is get the Koni's (front and rear) and the new adjustable camber plate from Ground Control and I'll have a tight ride. No more bouncy bounce.
Terry
Old Feb 22, 2002
Grey's Avatar
DIY King
See anibal's post.
Old Feb 22, 2002
SQCivic's Avatar
3rdcivic - I'm going to be using the Neuspeed Sport springs, Ingalls camber kits, and the Koni's. Would I still benefit from the new strut bearings and upper mounts off the 2k2?
CarStuff
Dec 6, 2020 12:52 PM
Civic2002lx
Oct 7, 2015 09:17 AM
stereobumps
69
Jul 14, 2015 08:08 AM
izdman
May 19, 2015 03:43 PM
CapYoda
Nov 11, 2001 05:17 PM
