EX head and ECU
Old Feb 12, 2002
C2i0v0i1C's Avatar
SuperMODrizd
EX head and ECU
If you were to take an EX head and an ECU and put them on the LX is there ne thing more that you would have to do in order for the vtec to work. and does the ECU store the mileage. or does the guages in the dash do that. if there is ne thing more that one would have to do for the vtec to work what would that be.
Old Feb 12, 2002
PsychopathicLX's Avatar
PsychopathicLX is an unknown quantity at this point
dunno why anyone would do that JUST for Vtec
Old Feb 12, 2002
C2i0v0i1C's Avatar
SuperMODrizd
The question is...would it work. if its cheap and its JUST for vtec then there aint a prob. i just want to know if there is ne thing else that would need to be done in order for it to work.
Old Feb 12, 2002
Voiceofid's Avatar
End Bringer
prolly need to change the cams too, and prolly the cam controller arm thing and other stuff...
Old Feb 12, 2002
SlvrEX5spd's Avatar
SlvrEX5spd is an unknown quantity at this point
yep you would need a vtec cam along w/ an oil line that goes to the head in order for the pin to lock into the bigger lobe on the cam and rocker arm engaging vtec
Old Feb 12, 2002
Dakker's Avatar
Giggity Giggity
Dakker is an unknown quantity at this point
man for our wussy sohc vtec it just aint worth the trouble
Old Feb 12, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
Everything to do with the cam is in the EX head already. If you get a hold of the EX head, then you don't need the cam. Another thing you need is the VTEC solenoid. ECU/Odometer question, I have no clue about that. I guess you could experiment if you have a friend that has a 2k1/2 and swap gauge clusters and see if your mileage readings change before/after...
Old Feb 13, 2002
aznboy808's Avatar
aznboy808 is an unknown quantity at this point
i think you have to make sure that the head of the ex matches the block on the lx too...some of the holes might be positioned differently
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
emich
May 29, 2016 06:32 PM
01civyv3
Jun 2, 2015 05:21 AM
Supramk3
May 11, 2015 07:55 PM
