help with turbo gauge
Old Dec 9, 2005
i'm having trouble figuring out how you connect that nylon tube to the gauge. I have a brass piece that screws to the gauge and some lil cylinder inbetween but it doesn't really tighten down. Is there something I'm missing? i'll try and take pics of the parts i have...
Old Dec 9, 2005
ajhdragon's Avatar
7thgens official a$$hole
you should have a little ebad loking thing that goes around the nylon tube. first slide the tube through the thread then that bead and have a little extra tubeing going through. then thighten down the threads. when you do that it pinches the bead and makes it air tight.
Old Dec 9, 2005
okay so the bead goes between the two metal pieces and then you tighten it. cool thanks.
Old Dec 9, 2005
ajhdragon's Avatar
no prob
Old Dec 9, 2005
tfnaaf's Avatar
BLDNPSI Mod
BTW that bead is called a ferrule fitting
Old Dec 9, 2005
nice. so i take it once you tighten it you need a new bead if you take it apart? oh i mean ferrule fitting?
Old Dec 9, 2005
ajhdragon's Avatar
yup pretty much. your gauge shoulkd come with 2 one for each end of the line.
Old Dec 9, 2005
tfnaaf's Avatar
BLDNPSI Mod
in therory its reuseable, just dont over tighten it
Old Dec 9, 2005
uh i only have one. for the other side (vacuum line splice), they gave me a universal T and some rubber hose to connect the tube to the T. It fits snug but seems like it needs a clamp or something.
Old Dec 9, 2005
ajhdragon's Avatar
when your actually boosting i reccommend you get a golden eagle vaccum box. it makes everything cleaner and really easy to work with. rather than haveing like 5 diffrent T's.
Old Dec 9, 2005
cool ya i was thinking that cause there's also the emanage pressure sensor to hook up. Any link to buy it?
Old Dec 9, 2005
ajhdragon's Avatar
i got mine off a memebr but im pretty sure you can get one off ebay, or from golden eagle. they run like $100. its basically just a box that you tap into your main vaccume line and then thread in the diffrent vaccume lines you need.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
HondaGuy7
Feb 22, 2016 01:00 PM
raymondxcho
Sep 29, 2015 09:00 PM
ktae13
Electrical
Sep 26, 2015 05:14 PM
260000milesgoal
Sep 25, 2015 07:41 PM
