help, cam won't come off
Old Dec 5, 2005
how does the cam pull off the head? I have it sitting here and it won't budge. I loosened all the valve adjusting screws (except two that are loose but the rocker is still tight). And also the other camshaft holder bolts are loose. The cam gear is still on. That cap on the other side is off. Now what? It won't pull off/
Old Dec 5, 2005
2k2civic's Avatar
Is the timing belt still on?
Old Dec 5, 2005
the head is on the living room floor. its the spare one im trying to clean. and the cam gear is off too.
Old Dec 5, 2005
2k2civic's Avatar
I've never actually pulled one off, but for some reason, I wanna say it has to come up and out (towards where the cam gear would go), don't ask me why I just said that, just a weird feeling I had.
Old Dec 5, 2005
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
you've removed all the bolts on the top including the 2 on each side. if all is loose then you should be able to pop it off with a flathead.. you have to remove them to pull the rocker arm assembly off.
Old Dec 5, 2005
2k2civic's Avatar
Wait, I'm pretty sure the rockers gotta come off
Old Dec 5, 2005
djmota's Avatar
just make sure that all of the bolts on the caps are completely loose. give the caps a light tapping with a rubber/plastic hammer to loosen them up. then the whole rocker/cam cap assy will come straight up. make sure not to let anything slide off. take it off as an assembly.
Old Dec 5, 2005
ya i know but not happening. ALL bolts are loose and still on, I hit it with mallet and it is stuck. The rocker assembly won't lift off. also the adjusting screws are loose except for 2. i undid them until it wouldn't turn anymore but there's still some pressure.
Old Dec 7, 2005
kileryoyo's Avatar
kileryoyo is an unknown quantity at this point
When I diassembled my new head to put on my new cam I had the same problem you are. I had some silcone? sealer around the edges of wher ehte rocker assembly and the head meet. It took a bit of prying to seperate the assembly and the head to take out the cam.
Old Dec 7, 2005
ya i got it off the same day finally. took alot of muscle and screwdriver action after banging with a mallet for a minute.
7thgensurvivor
Aug 26, 2015 06:17 PM
Green02civic
Jul 27, 2015 10:48 PM
EM_WON
Jul 22, 2015 06:49 PM
General 7th Gen
Jul 9, 2015 10:17 PM
Ccoop87
Jul 9, 2015 03:26 PM
