Wheelbearing DIY
Crayons taste like purple...
ok I looked online @ Autozone....anyone have any idea what all it is I need to purchase?
CIVIC wheelbearing page
Mines in the car and I'm not going out in the rain and cold, but sounds like you just need the bearing?
Originally Posted by pon55
RTFB has been the answer for like 1,888,765,897 years!
I would RTFB if I wasn't poor (buy it) or someone could link me or adobe me the pages DUHR!!!
thats why I asked
I would hope it would just be the bearing, but if it needs pressed I'm pretty sure i'm not gonna do this as a DIY, I'll just buy the parts and get them installed for labor rate only.....I'm guessing bearings are bearings when it comes to our cars right? single tapered as long as it fits....
thats why I asked
thats why I asked
http://www.hondaautomotiveparts.com/...y5=FRONT+BRAKE
gives you the parts,ect!
look like a press fit in the hub which you can probably do (carefully) with a vise!
The first thing to do is go to
Originally Posted by djmota
All you need is the bearing.( around 35.00 from majestic for a real honda one) A vise will not cut it for this job. you NEED a hydraulic press and a few press tools to support the hub assy. the job is a pain. If you want a diy do some searches on honda -tech the procedure is the same on most civics.
you are just supposed to replace the "hub assy" It cost $43 for the rear I just did. Its a really easy job. Pull the drum, take off the spindle nut and the hub comes right off (for the rear). The front should be pretty much the same.
http://www.hondaautomotiveparts.com/...+BRAKE+%281%29
hondaautotiveparts.com=majestic
I suggest buying the part and taking it to a mechanic to have them do it.
There is an inner bearing race that stays on the hub and is next to impossible to get off without a special seperator tool.
I did my Accord. First took it to a shop and they couldnt do it and they had a press. So I just bought a used assembly, instead of just the bearing, didnt have to press anything. 60K later and the used one is still going.
Originally Posted by Overboost
I thought I needed to replace the wheel bearing myself but it turns out it was the heatshield touching the hub. Might want to check that first.
has anyone done one of these yet, or have a DIY for replacing them?
never did thank you for the DIY....thanks hehe.....oh and as it turns out I was thinking I got screwed on the bearing type.....cuz on the past links in this thread, I double checked and the pics were for DX-2-dr I have an EX-4-dr, so the prices were/are different, but really, is there a difference in the bearing itself? I mean aside from the fact that the front brake components (certain ones) are modified ina sense for ABS and such, why is there a diff of nearly 20 bux for what i paid for 4 dr than what I would pay for 2 dr?
Re: Wheelbearing DIY
The images where pulled from the actual Honda service manual. You can do a search, then down load it. It is the real deal, the actual Honda one that the techs have, not the one you buy at the parts houses.....
Ziggy1999
Oct 15, 2015 07:56 PM
meicalnissyen
Sep 25, 2015 12:12 AM
