Stock air box.
For every sprinkle I find, I shall kill you.
Stock air box.
I had my oil changed at a couple different places the passed 3 times and during one of those times when whoever was checking my airfilter, they tightened the screws too tightly and snapped a pastic piece on the bottom half of the box
. So now when i go to remove the top half to check my filter, 4 of the how many screws just spin the nut holding it down....
My question is, can I remove the entire air box without taking the top piece off first? I checked the DIY for the AEM CAI to see if it showed what all had to be removed but when it got to the step of removing the bottom half it didn't say where any screws were to remove it. If I can get the box off I can probably fix the problem. Otherwise I'm hopefully going to be buying a used one from a fellow member....
I don't have the money to invest in an AEM or INJEN intake or anything brand name. Best I could afford right now would be an ebayh intake. And I know you all know what I mean by an ebay intake. One where the shipping is 3 times the final price you pay. I don't know how many of you have them but would you recommend it? It's either that or staying stock, and I am quite happy with the way things are. Thanks!
. So now when i go to remove the top half to check my filter, 4 of the how many screws just spin the nut holding it down....My question is, can I remove the entire air box without taking the top piece off first? I checked the DIY for the AEM CAI to see if it showed what all had to be removed but when it got to the step of removing the bottom half it didn't say where any screws were to remove it. If I can get the box off I can probably fix the problem. Otherwise I'm hopefully going to be buying a used one from a fellow member....
well there is a small clamp holding a rubber thing around the throttle body. then there's four big brass screws and the engine breather. then you can start pulling up hard. don't forget to take out the sensor on the side first. and if lid screws are stripped/broken, you'll have to pry it open somehow or drill away the plastic. either way you need a new one.
the ebay intakes arent bad their just not brand name. i have one i have driven 7thgens with aem's and i couldnt tell the difference. but if your going for look buy the nice ones other than that ebay will save you cash if you wanna little more kick in the throttle.
Drunken Master-7thgen Ninja
or...you could look in the FS section with the billion people selling their intakes,ebay and name brand. some guy is selling his ebay intake for like 30 bucks shipped. have fun.
Same thing happened to me. I put a flathead screwdriver between the lid and the bottom side of the airbox where the affected bolts were and pried up as I turned them with another screwdriver. I only had two and it took me quite awhile. The other problem is finding something to be the leverage for the flathead.
lilrob1213
37
Jun 29, 2015 06:45 PM
Ninetyatecivic
May 9, 2015 07:48 PM
cloudguy
Apr 28, 2015 05:02 AM
