Help with my M3 power mirrors
i donn ab a 95 but my 03 has 3 wires i knew that the green was the ground, i just played with the other 2 till i got the mirror moving the right way. When you push the up and down you don want the mirror moving left and right, same with left and right. Just take a few min to figure it out. Most likely you'll have to cut off the factory connector to wire the m3 to the factory wiring.
the wires from the oem connector are green/black......blue/green and yellow/white Im thinking the yellow is the hot one and the green/black is the ground hopefully the white wire from the M3 mirror goes to the blue/green......thanks for the help
jessicanicole
Jul 23, 2015 09:14 AM
breanna_17
Jul 21, 2015 04:01 PM
igorbogu
Jul 10, 2015 09:29 PM
