Transmission Temperature Gauge
Either way you're gonna have to tap a fitting in there. You can use an electronic one. Just get an oil temp gauge, but its not like there's a hole just sitting there waiting for you to stick a sensor plug in it.
Originally Posted by joe6680
Uhm why not just drive normal....Even if you have a temp guage it'll do nothing for protection....Your better off getting a tranny cooler then a guage....Or like I said drive normal.
i'm smackin this throttle 100% all the time. got a tsx front end waiting to go in. steppin on a motor/tranny you know you're gonna replace is one of the most fun things to do in life. even with my race bikes i'm aware of how i'm abusing the components, but with a stock gokart (aka Civic) i'm slidin around every turn possible waiting for **** to fall off
jokes aside, a tranny temp guage has saved my *** previously in two cars, which were both bigger displacement motors, but i woulda ended up blowin seals and maybe stickin gears together if i hadn't know my tranny needed to cool down for a bit before more full thottling on I5 during the a few trips to SoCal. at about 110 for an hour and a half straight you'll probably need some additonal cooling for that small-bearing civic tranny
tapping into the coolant line sounds like a workaround... i'll check it out
cizsak
Jul 21, 2015 03:39 PM
Kyles24
Jul 12, 2015 09:15 PM
