E-Break Noise?
Old Nov 6, 2005
Dfresh7's Avatar
Dfresh7 is an unknown quantity at this point
E-Break Noise?
Does anyone else have this problem?
For afew weeks now I have had a vibration in my e-break while im driving. I have no idea how it happened but it has been getting worse. Im spending the day working on her so if anyone knows how to fix this then that would be great.
Thanks
Old Nov 6, 2005
manahoonie's Avatar
i'd say check your brakes...i think the rear ones...
cause my friend would hear a grinding noise in the front passenger siede wheel well everytime he made a right turn. it turned out that a clip had broken, and his brake pads would just wear away as the rotor spun, becaue after depressing the brake, they wouldn't pull back out. it ended up scarring his rotor. luckily enough, he didn't have to replace the rotor..
Old Nov 6, 2005
tfnaaf's Avatar
BLDNPSI Mod
Thanks
im confused, do you mean your driving down the road and you can feel a vibration in the e-brake, or you apply it while driving and feel a vibration? Just an FYI its called a E-brake for a reason. It's not made to be used while driving down the road to stop the car. ANYWAY, if it vibrates as you pull the e-brake while your driving it most likely is a drum thats egg shaped and needs machined to true it up.
Old Nov 7, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
Is he talking about the "handle" making noise. You know like one of the other annoying interior noises.
nirvanaguy
25
Oct 26, 2017 07:26 PM
fvckbg
Sep 8, 2015 09:55 PM
Josh 1973
Sep 7, 2015 10:10 AM
junkyardguy
20
Sep 6, 2015 10:07 PM
tommycanada
Sep 5, 2015 04:59 PM
