exterior door handle problems
Old Nov 3, 2005
madelinepackard's Avatar
madelinepackard is an unknown quantity at this point
Question exterior door handle problems
please help me! the handle on my driver side front door has cracked and is about to break off. My fiancee can't get it out. anybody know how to remove it? It's a 2001 civic ex sedan.
Old Nov 3, 2005
mradam85's Avatar
mradam85 should not be trustedmradam85 should not be trustedmradam85 should not be trusted
how to get what out?
Old Nov 3, 2005
SimonTek's Avatar
SimonTek is an unknown quantity at this point
use the passenger door?
Old Nov 5, 2005
I need to replace the handle you use to open the door from the outside of the car. I'm not using the passengers' side climbing over the e-brake is a b*. So if anybody has a DIY for this please help.
Old Nov 5, 2005
CenZ's Avatar
PWIT
its not that hard, i havent done it on a 7th gen but i did it on a 6th gen. take the door panel off on the inside, should only be like 3 bolts and then it just clips on. then peel back the plastic on the door. then you will see metal rods going around in there, (oh btw make sure the window is up) one will go up to the handle. on that handle there is a plastic peice the rod is in which connects to a arm on the handle, just pry that off, there there is 2 bolts i beleive holding it on and handle should just fall out.. lol. not the best description but if you look at the inside of the door you will see what im talkin about lol.
Old Nov 5, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
i'm sure you've takin out the 2 bolts holding it on and you the locking mechanisim is stuck and ur forced to yell, throw, hit, ****, and masterbate on it, when your dont ranting at it, there is a "C" clip that holds then mechanisim on, it's right behind the lock and is actually part of the door handle
Old Nov 5, 2005
shroomster's Avatar
Crayons taste like purple...
shroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to beholdshroomster is a splendid one to behold
geez masturbation doesn't solve all the world's problems....cept feeding the hungry....
lord I apologize and please take care of those starving pygmies down there in floobaboobadooba...
On a more serious note anyone think that a door handle repaint would cost under $25? (reason=wal-mart cart)
Old Nov 5, 2005
booba5185's Avatar
i'd say so, u might be able to paint it yourself, just like how eveyone paints their m3 mirrors.
Old Nov 6, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
vgon24
May 12, 2015 09:16 PM
Cypher
Dec 15, 2001 07:25 PM
rallyred2k1civic
Dec 8, 2001 11:49 AM
CivicHX01
Nov 2, 2001 08:49 PM
