best way to reduce exhaust vibrations?
Old Oct 17, 2005
  #31
vietstylez's Avatar
rain gets the pipes wet, which in turn causes them to expand. bigger pipes = closer to frame = rattle
Old Oct 17, 2005
  #32
i'll see what happens when rains again
Old Oct 17, 2005
  #33
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
man, that is hard to imagine, i didn't realize there was such a close tolerance.
I have had my RSR EX MAg for 2 years now with no problems.
Old Oct 18, 2005
  #34
7thGENDMAN's Avatar
7thGENDMAN is on a distinguished road
Yeah it really depends on the catback... Most have pretty good clearance, but there are some that just knock all the time. I've had both. The obx catback rattled a little, but when I picked up the Thermal R&D from gearbox, I had no problem. Its really just the length of the pipes and where each specific company put the bends in the pipe. Even a slightest tweek and bend changes an angle and things just fit too close.
Old Oct 18, 2005
  #35
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
Originally Posted by 7thGENDMAN
I guess I forgot to tell you to tighten up the bolts again. Once they are loose, try and twist the exhaust away from the frame and with pressure on the exhaust, tighten up the bolts. This should keep it away from the rail.
hrmm i still think even after u have tighten up the bolts u may or may not have leakes around the cat-mid pipe and rear piping-mid piping. cause basically all u are doin is pullin it down and the way the piping connects with each other is meant to sit one way basically and any other way may cause a leak. anyways i think the cat is the problem (not sure if thats cat-back) cause some pplz have diff cats or even just left the oem on and had no problem and some did w/ aftermarket ones. i guess im gonna have to try the twist and pull strategy on my exhaust nd see if that works.
Old Oct 19, 2005
  #36
PiNoYxRaCeRxRH's Avatar
PiNoYxRaCeRxRH is an unknown quantity at this point
what'z pb blast?
Old Oct 20, 2005
  #37
its like wd40 but better and faster.
Old Oct 20, 2005
  #38
down_'s Avatar
Broken Arm, How Am I Suppost To Shift
down_ should not be trusteddown_ should not be trusteddown_ should not be trusted
I have the same problem. Only its not just a little rattle. its more like a kNOCK KNOCK under the passanger seat... it only seems to happen when it gets REALLY REALLY HOT out and i turn on the A/C or fan. hasnt happend latley i hope i dont jinkx myself but anyway... thats my situation
Old Oct 20, 2005
  #39
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
i have this issue with my stock exhaust on my 01 hitting my neuspeed x brace. i have put dynamat on the x-brace but that just made it a deep rattle instead of a high ting.
jdawgzcivic
17
Feb 1, 2020 04:16 PM
nirvanaguy
25
Oct 26, 2017 07:26 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
FistRock
Sep 4, 2015 08:00 PM
