a/c not cold enough
Old Jul 31, 2005
  #31
AlienX's Avatar
AlienX will become famous soon enough
http://www.duracool.com/Duracool/acsolutions.html
mobile product at the bottem will remove any moisture in the system, stop leaks in the system and replace any refrigerant oil that may have been lost as a result of leaks. This even for cars that are 2 years old
Old Aug 1, 2005
  #32
invrtdsa1nt's Avatar
invrtdsa1nt has a little shameless behaviour in the past
mine sucks alot, it has never gotten me cold. ive had one complain to turn it down, at night when it wasnt even needed. even though its usually 110 + here on a summer day in august, it should work better.
Old Aug 1, 2005
  #33
SLVR01CIVIC's Avatar
SLVR01CIVIC is an unknown quantity at this point
how about us people that live in phx az? when it takes forever to for the a/c to keep up let alone keep the inside of the car cold enoughwhen its 110+ here. mine is alright if it is just me in the car with all the vents pointed towards me!
Old Aug 1, 2005
  #34
White05EXSE's Avatar
White05EXSE is an unknown quantity at this point
...it's fairly hot here in TN, I don't have any problems with my A/c, it's cold almost instantly; in fact, it's colder in the civic than it was in my beast of a volvo s80. Could adding a CAI be a factor; I mean, you're supposed to be recieving more, colder air; right? just an idea.
Old Aug 2, 2005
  #35
AlienX's Avatar
ur 2 funny
AC works on compressing gasses causing them to become liquid, and cooling though a condensor that is right before ur rad if u look in the engine bay. Read up @ linky.. It has nothing to do w/ the intake system of a car.
http://home.howstuffworks.com/ac.htm
Old Aug 2, 2005
  #36
Jrfish007's Avatar
Remeber this guys/gals, A/C is taking heat from inside your car and expelling to the out side. That's right, the it is actually removing heat from the air and putting to the outside of the car. With out getting into how refigeration systems work, the hotter it is out side the less effiecent your A/C is.
So A/C will not work as good when it is 110F compared to when it is 90F (given the same humidty, and yes humidty plays a roll in how good your A/C works too). It sucks because you need it more as it gets hotter, but that's just how the thermodynamics work Your A/C just can not put more heat in to hotter air. Think of when you fill a tire, when the tire is really low (say like 10 psi), air moves really fast. Then as the tire inflates more, the air slows down and it becomes harder to push more air in to the tire as it becomes higher in pressure. The A/C works the same, it is taking heat out of your cabin and putting it into the enviroment out side (the out side is like the tire, as it gets hotter out side, it's like the tire getting fuller).
Old Aug 2, 2005
  #37
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
uh...right.....ive driven in my parents car during the day when it was a blistering 100 degrees + and their ac's are blistering cold. now tell if your statement is right how come theirs is like that? just wondering and im not sayin your write up is wrong in any way.
Old Aug 2, 2005
  #38
Jrfish007's Avatar
Do both of you have the same car? It is very depdant on how the system is made. For instance, I've noticed GM has what I think is one of the best A/C systems. They happen to use a 2.5 ton coolling system (that what most decent sized homes have) where as Honda goes with a little smaller system. The larger system can pump alot more heat out than a smaller system. So if it looses effiency, that's fine, it's big enough to compinsate. The advantage to the smaller system is that it isn't as much of a drain on your car's motor (your MPG will suffer). If you put the GM one on a civic, when you turn the A/C on, if the car is still running, you will have the acceleration of an Insight and the MPG of a truck. Older Honda's (the ones that ran on R-12) are very cold, if they are still running R-12. So even with in the same band there will be variation. In short, different car, different systems. Now if you both have same year make and model, something is up.
Old Aug 2, 2005
  #39
WhiteCastle's Avatar
my ac for some reason only works in two modes.. On and off. its either spitting out freezing air or it doesnt work.. I try to make it go inbetween or less cold than it is I get a mad moisture problem! is it because I havent replaced my micron filter and im at 36 thousand miles?
Old Aug 2, 2005
  #40
Jrfish007's Avatar
Originally Posted by WhiteCastle
my ac for some reason only works in two mods.. On and off. its either spitting out freezing air or it doesnt work.. I try to make it go inbetween or less cold than it is I get a mad moisture problem! is it because I havent replaced my micron filter and im at 36 thousand miles?
Unless you filter is severly clogged, that's not a filter problem, check out, try running the system with out the filter and see if that helps, but I doubt it will do anything. Sounds like a relay or an electrical problem between the temperature dial and the valve to me. Find a place that specializes in A/C repair is about all I can say, sorry
Old Aug 2, 2005
  #41
crazyasian's Avatar
i got this wierd smell comin out of my a/c and i dont know y b.c i just bought the car in April 05. anyway i can fix that?
Old Aug 2, 2005
  #42
AlienX's Avatar
what year did u buy ?
Old Aug 2, 2005
  #43
crazyasian's Avatar
april of 2005
Old Aug 2, 2005
  #44
Jrfish007's Avatar
^^^ I think you are saying you bought it new right?
Anyway, funky smell is generally 1. a fungus on the inside of the venting that has grown becasue of some small water collection or 2. a small leak in R-132 to air heat exchanger. It's probably number 1. What I would do is turn the A/C on all the way to max, roll down all the window on a hot dry day and drive for about 30 minutes to an hour on the free way. This should get the water/condinsation out. If this doesn't fix it, take it back to the dealer and complain, assuming it a new car it should be under warranty.
Old Aug 2, 2005
  #45
crazyasian's Avatar
aite ill try that out tommorrow if i ever go out. thx
Old Aug 2, 2005
  #46
gh0st's Avatar
TAQUITOS!!!!
my dad's AC in his lexus smells like mildew when you turn it on...it makes me sick.
other than that, i recently had my AC recharged or replaced when honda had to do work on my front end. it seemed to work alot better after that...
Old Aug 2, 2005
  #47
AlienX's Avatar
even if it is new, i would double check the cabin filter for any kind of build up. Just remove the glovebox by sliding back the black clips ( full, accurate instructions in ur manual.
Old Aug 3, 2005
  #48
Jrfish007's Avatar
That's a good idea too, water can collect in there, although it is hard for mildew to grow on activated carbon, but it can happen.
masongardner
Air Conditioning
21
Jun 29, 2019 05:10 PM
andyandyy
Aug 4, 2015 06:37 PM
Jul 14, 2015 03:39 PM
