Custom Cold Air
Ok i was thinking, pretty much the stock air box is the best intake for our cars both low end and high end. i was wondering if this would work. theres a Whole near the stock intake tube leading down the under the fender well. if u measured that intake pipe diameter (cause a diff diameter would change the pressure and thus change the effect it has on the car) same Diameter and ran in down the whole (might have to dremel a lil bit) and put a filter on the end of it and took the stock filter out. You woudl still be usuing ur stock air box but it would be a "colder" intake than u had before. What effects woudl this have on the car. Has anyone tried anything like this.
Drunken Master-7thgen Ninja
what kind of piping would you use? if you go to autozone they have cotton intake filters and plastic extensions for intakes. so if you wanted to you could make your own intake from that stuff. i guess you could keep the stock box but why? it takes up so much space. i would take mine the hell out if it didn't void the warranty. anyway good luck. and try to shield the filter so water don't get all up in there and cause your motor to hydrolock. cause that would suck
my typhoon intake has more low end than stock. But if you wanna mess with the stock one, just change the tubing and extend it lower. Don't take off the resonator cause thats where most of the power comes from.
dont need to add another air filter to it, that would just mean less air flow. if your keeping the factory airbox, it has a filter element in there that works great. so i think extending the inlet pipes would be the best bet.
mrohitredd
May 30, 2015 06:51 PM
jc33312
May 12, 2015 03:17 PM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
