redline problem
Old Jul 5, 2005
jdmcivic01's Avatar
jdmcivic01 is an unknown quantity at this point
redline problem
i have civic 01 hx auto and i was wondering if this is normal when i floor it. It stays at 5000 rpm and it doesent go beyond that and i was wondering if this is normal for the hx auto because there isnt enough power this would help me out alot thanks guys
Old Jul 5, 2005
7Gnoob's Avatar
7Gnoob is an unknown quantity at this point
Mine goes right to redline. Manual trans.
Old Jul 6, 2005
um its supposed to go higher if there's more rpm before redline. Look and see where the red starts. And don't you need to put it in sport mode or something?
Old Jul 6, 2005
jttegx's Avatar
OMNES AD UNUM
hopefully your not going this on public roads.
but push the pedal down harder. does the rpm tach reach its "redline" point when u gun it all the way down? if your talking about the final gear (4th), then its the governor
Old Jul 6, 2005
my1vtec's Avatar
my1vtec is an unknown quantity at this point
well i dont kno, but this happens to me when i rev it in nuetral, only 5000 rpms...
Old Jul 6, 2005
dalaw's Avatar
Bone Stock!
probably a vtec malfunction that causes it to go into safe mode and limit the revs to 5000 rpm.
I hope i didnt make this up, i just remember a couple years ago some guy with a ITR told me the same thing happened to him.
Old Jul 6, 2005
jdmcivic01's Avatar
when i oush the pdal down harder it just stays at 5000 rpm and my redline is 7000rpm thats when the red mark starts
Old Jul 6, 2005
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
you need to put it in S with the CVT to go to redline ?
Old Jul 6, 2005
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
yes when you are in neutral you can't pass 5000 but why would you want to do it though? Do a burn out?
Old Jul 7, 2005
jdmcivic01's Avatar
not in neutral im not trying to do a burnout just when im at the track it dosent go to redline. i was wondering if my power just stops at that point
Old Jul 7, 2005
MadWheel's Avatar
Premium Boosted Member
CVTs aren't supposed to redline from what I remember. It's constantly variable, meaning it's purposely compensating the gear ratio as you accelerate. Your peak torque is at 5k, it's just the system keeping the ratios in your maximum power range. If you went higher in rpms, it would stress the engine a lot, and you'd be even slower, so there's no point.
jackoncruzpr
May 24, 2015 12:24 AM
normaspirated
Apr 26, 2002 03:04 PM
pazzmore
Dec 24, 2001 07:39 PM
Waldo
Nov 10, 2001 01:04 PM
spoony
Nov 7, 2001 11:01 AM
