Exhaust Install
Old Jun 3, 2005
Logovaz's Avatar
Logovaz is an unknown quantity at this point
Exhaust Install
What is the right way to install a 3 piece exhaust? I mean where the mid pipe is connected there are holes and I am guessing the exhaust gases are not suppose to leak out but I tried to insert one piece into another as far as possible but it still seems to leak. Any suggestions. I have a HP Racing Jspec Catback Exhaust.
Old Jun 3, 2005
R1Style's Avatar
You probably need exhaust gaskets inbetween each connection. You can buy them at any auto parts store.
Old Jun 3, 2005
Logovaz's Avatar
What gasket are you talking about? this is one of those mid pipes that connect with a clamp and not bolts. so i guess unless i am missing something I don't know which gasket you are talking about.
Old Jun 3, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
If its a clamp connection then put one inside the other and clamp it. However I highly recommend you take that to a muffler shop once the exhaust is intalled and have them weld the clamped joint shut.
Old Jun 3, 2005
R1Style's Avatar
my bad... I was under the impression that you had flanges.
Anyways, Boiler hit the nail on the head... go get it welded together that way you get no leaks.
Old Jun 3, 2005
Logovaz's Avatar
thanks
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Inkubus
Bolt-on Engine Performance
Jun 30, 2015 12:11 AM
Inkubus
Jun 26, 2015 11:42 PM
Reverb2005
Jun 26, 2015 06:22 PM
kanin247
Apr 25, 2015 05:44 AM
