Is it worth it......
Old Apr 13, 2005
P.O.S.B.A.S.04's Avatar
Ever Wonder What P.O.S.B.A.S. Is An Acronym For
P.O.S.B.A.S.04 will become famous soon enoughP.O.S.B.A.S.04 will become famous soon enough
ighty, i bought my header about 6 months ago and it has been sitting in my closet since then. i wanted to put it on but i did not know whether or not it is worth it to put it on since i do not have a down pipe/hi-flow cat......any thoughts (besides i am a retard for letting it just sit there)?!?!?
Old Apr 13, 2005
R1Style's Avatar
Just put it on... you have it you might as well use it. You might gain 1 hp!
Old Apr 13, 2005
djmota's Avatar
just put it on, its to easy not to. You might see some gain in the higher end.
Old Apr 13, 2005
PunkingCivic's Avatar
I need TP for my bunghole
I'll take the header off your hands as a donation!
Old Apr 13, 2005
es2k2's Avatar
Proud to be a civic owner
yeah give it to me if you don't want it
:-D
Old Apr 13, 2005
Marcus's Avatar
And Pimp I got the Juice
Marcus will become famous soon enoughMarcus will become famous soon enough
Can't you since ur a EX use the top part of the header and use the stock EX everything else as in the Cat, and the rest of the pipe becuase ur cat Isn't hooked up to ur header....
Old Apr 13, 2005
Marcus's Avatar
cAN'T U still use it *
sorry typo
Old Apr 13, 2005
I can still use it, I just did not know if I should get a HiFlow cat first or not......sorry no donations will be made at this time....thank you for your suggestions to do so
Old Apr 13, 2005
BERGER's Avatar
BERGER will become famous soon enoughBERGER will become famous soon enough
i'm going to be buying a header maybe and just keep the down pipe and cat stock... don't have the money for the rest right now... have other things in mind first....
Old Apr 14, 2005
yeah, fair enough to that berger. i just do not know where to start though
Old Apr 14, 2005
CapYoda's Avatar
Escaped Convict
welp, there's some DIY floating around for header install.
what kind did you buy and for what car model?
basically you remove the two spring bolts from the BOTTOM of the car.. jack the front of the car up a bit if you want to have more remove.. unbolt the bottom two spring bolts that connects header to downpipe.
unbolt them alternatively (as in, unscrew a bit for the one on the left.. then do a bit for the one on the right - the spring in the bolts gives the tension...)
then open engine bay, get the 2 bolts on top and 1 bolt on bottom of heatshield.. remove heatshield...
take out the 4 nuts.. and get an extension so you can get the one on the far right.
now reinstall in reversal order.
remember when you put back on the bolts on the bottom, to bolt it back on alternatively, so that the spring will give correct tension.
um, also remember to transfer the gasket between the header and downpipe.
what else.. make sure u torque all bolts to correct specs.
you can search more on the torque specs, and search more on DIY.. maybe there's pics floating around too.
Dawit Melese
Oct 4, 2015 08:02 PM
jackoncruzpr
Sep 29, 2015 07:59 PM
deanaZoom
35
Sep 19, 2015 12:22 PM
Jrosa
Sep 14, 2015 08:24 PM
Bikergofast
Sep 12, 2015 01:36 PM
