porting the intake
Old Jan 1, 2002
insan's Avatar
insan is an unknown quantity at this point
porting the intake
i was thing about just porting the intake manafold. my buddy said its only 155. to do. know if i just do this for now, how will motor run? will there be more power or just get better gas milage?o'yea what is the polish part? is that where u bore it and replace the pistons or something
Old Jan 1, 2002
01civicboi's Avatar
01civicboi is an unknown quantity at this point
finally a real mod [IMG]i/expressions/face-icon-small-smile.gif[/IMG] theoretically you should get more power since ur freeing up that manifold. i dunno if you'll instantly see the results. maybe if u had a dyno that would help. keep us posted if u get it done
Old Jan 1, 2002
bth Go Army's Avatar
bth Go Army is an unknown quantity at this point
what about running lean...any thing to worry about there? I was thinking about port and polishing everything i can! =)
Old Jan 2, 2002
02Si's Avatar
02Si is an unknown quantity at this point
Reset ecu after mode, should take care of the running lean prob.
Old Jan 2, 2002
2k2civic's Avatar
How much does a port and polish typically cost for a car like ours?
Old Jan 2, 2002
drbombay's Avatar
drbombay is an unknown quantity at this point
make sure the person that does it for you has a flow bench.
Old Jan 2, 2002
Swifty's Avatar
From: Ricemond B.C. Canada, British Columbia, Canada
Swifty is an unknown quantity at this point
The typical home port and polish job consists of Gasket matching this is when you make the openings of the intake and head match the size of the gasket hole...other than that you may want to clean up any casting marks and radius the short side of the intake runners...when polishing dont use any finer than a 80grit sand paper or the ports will become too smooth and the air will become too turbulant in the intake and head....other than that when doing the Exhaust ports on the head only raise the port roofs or you will loose power in this area, but gasket matching is still fine here.....getting the head ported properly with a rebuild and larger valves, and bowl work will probably run you around $1500, and having the intake extrude Honed will probably run around $500...and net you around 15hp...but this is the way to go if you plan to add forced induction.....Remember more air in and more air out = more HP....but you cant have any bottlenecks anywhere....but if you are mechanicly inclined the home port job is good for about 2-5HP
Click HERE to see a home porting kit
Old Jan 18, 2002
2k1EXracer's Avatar
2k1EXracer is an unknown quantity at this point
I thaught our intakes were plastic? I didnt think you could port plastic[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 18, 2002
Slammed2k1's Avatar
Slammed2k1 is an unknown quantity at this point
I was wondering about that myself...
Old Jan 18, 2002
01civicboi's Avatar
i believe he was referring to the intake manifold, not the actually airbox.
Old Jan 18, 2002
Dakker's Avatar
Giggity Giggity
Dakker is an unknown quantity at this point
hehehe, yeah you will feel gains if you do this, about the same as adding an aem intake
Old Jan 19, 2002
Slammed2k1's Avatar
<< i believe he was referring to the intake manifold, not the actually airbox. >>
Yes, which would be plastic.....
Old Jan 19, 2002
GTekCiViC's Avatar
GTekCiViC is an unknown quantity at this point
Porting ur exhaust manifold is a better mod than your intake manifold........
Old Jan 19, 2002
2k1EXracer's Avatar
you cant port either our intake or exhaust manifolds.
our intake manifolds are plastic and our exhaust manifolds are tubular steel. you only port things that are thick cast metal.sorry![IMG]i/expressions/moon.gif[/IMG]
Old Jan 19, 2002
Bartkat's Avatar
Dakker.
Would you mind removing that cartoon? I've seen it on more than one thread and it causes a delay when loadiing the page.
thanks.
Old Jan 19, 2002
GTekCiViC's Avatar
i guess that's true..........
UltraHDGames
Jun 8, 2016 05:16 PM
ThatGuy913
Nov 9, 2015 06:31 AM
juicetayne
Sep 30, 2015 11:02 AM
Cam Diaz
Sep 29, 2015 07:17 PM
thaler4cuse
Sep 7, 2015 08:25 PM
