installed header, now problems
Old Feb 18, 2005
I replaced my replica header with a kamikaze top portion for ex, now there is a constant rattle noise around 2500 to 3500 rpms and I can smell gas coming from the header. What should I do? I had to use the old gasket which is ported larger than stock.
Old Feb 18, 2005
injencivic's Avatar
injencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of lightinjencivic is a glorious beacon of light
hmmm, try getting a new gasket from honda. Or did you make sure you tightened everyting up(i am sure you did, but i would double check). Is it a loud constant rattle or does it just rattle when you rev your engine?
Injen
Old Feb 18, 2005
well it only does it between those rpm ranges while driving. I can rev the engine and don't hear it. It just started after the header install so I know it's that. Everything is tight, the gasket needs to be ported bigger so prolly isn't sealing, but the rattle I don't know.
Old Feb 18, 2005
injencivic's Avatar
I dont know man, i guess take it to a shop and have them look at it.
Injen
Old Feb 18, 2005
shmik1's Avatar
dude thats how mine is too!! it only makes its noise when im driving, reving it wont do it.. i think im'a recheck how tight the bolts are? maybe they needed time to sit then re-tighten, thats my only guess.. but the noise it makes really sounds like the gasket is makin noise cause its a faint sound of thin metal rattling, or thats how it sounds to me, mine isnt exactally a rattle its just a vibration kinda noise... not really a metal on metal sound..
is that what you were trying to get me to hear? about the same thing I descrbied mine is doing?
Old Feb 18, 2005
DJ_NILOCIVIC03's Avatar
DJ_NILOCIVIC03 is an unknown quantity at this point
that used to happen to me too after a installed HP header and Hi-flow cat-back.....but I started to notice that so whatwas happening was that the springs that go between the header and the down pipe in my case the hi-flow cat weren't long enogh because its different and I had to get a new gasket you know that doughnut type....2 1/4 " ...and know I don't have that problem!
Old Feb 18, 2005
Well actually the sound I was getting was exhaust leaking....I had a metal to metal in the back cuz I had to adjust heat shield that was bent....
Old Feb 18, 2005
Um well I only hear the noise around 2800rpms and it goes away if I rev further or shift. Ya one of the top bolts was loose, but that didn't help when I tightened. I still smell gas and it's rattling all the time. Could it be something with the downpipe touching somewhere on the bottom? This sucks!
Old Feb 18, 2005
But If you Still smell gas....that means there is a leak... check for that gasket between the header and the down pipe....sometimes that gasket moves when not its not tight enough...
Old Feb 18, 2005
Where was yours rattling from? I felt around and everything seems tight and secure.
Old Feb 18, 2005
between the header and the down pipe. the way the stock down pipe fit with the stock header its a lil bit different...
Old Feb 18, 2005
actually the bottom part of the stock header its what is different...
Old Feb 18, 2005
I'm guessing, but maybe the downpipe is closer to the car and rattling against it?
Old Feb 18, 2005
maybe....but then where are you getting that gas smell from?
Old Feb 18, 2005
scatman's Avatar
Still in the game...
make sure everything is tight
check all the clearences
get a new gasket from honda
Old Feb 18, 2005
i'm not porting another gasket. It will prolly leak as well cause ports are big.
Everything is tight, the car feels good driving around, I'm really thinking the downpipe before the cat is rubbing the car. It does NOT make sound when cold. Only after the car warms up do I start hearing it. Would wrapping the pipe with thermotec heat wrap do the job?
Old Feb 18, 2005
shmik1's Avatar
hmm im'a have to see if mine is close to anything.. maybe i should get some wrap too
Old Feb 18, 2005
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
Gasket.
Old Feb 18, 2005
Logan3024's Avatar
Heres my theory "thermal expansion". i think you ported to much. you gotta remember that metal expands when it gets hot. Here the pic you showed me of your port job. Those cracks between the flange and the header pipes are probley leaking causing the rattle sound.
maybe not but look into it.
Old Feb 18, 2005
do you think it could be the downpipe? I felt under there and I can barely fit one finger between the chassis and pipe. I think that's the rattle and it only does it once the car is warm and pipes expand. About the ports, I don't think that's a problem. The welds are still there from the outside. I didn't grind into the welds at all. So would wrapping the pipe help if that's the problem?
Old Feb 18, 2005
Logan3024's Avatar
i dont know looks like you "ported" the inside welds off
Old Feb 18, 2005
Um no trust me on this. The way the header was designed, the tubes did not get ported at all, just the top part which had a 2mm lip all around. So actually when I first got it the top opening was smaller than the tubes. I just evened it out.
One problem is the old gasket was very thin around the edges. I might just have to port a new one again to fix it. Still don't know about the rattle. Everything is bolted on real tight.
Old Feb 18, 2005
Logan3024's Avatar
I trust the pics! That 2mm lip is called a weld.
and thats a EX oem manifold
4 banger
Jun 5, 2015 01:44 AM
Youshoe
May 22, 2015 09:36 PM
SlvrEX5spd
Nov 17, 2001 10:11 PM
SlvrEX5spd
Nov 17, 2001 03:33 PM
Flatlander
Nov 16, 2001 05:38 PM
