Where does the.......?
Old Feb 10, 2005
DJ_NILOCIVIC03's Avatar
DJ_NILOCIVIC03 is an unknown quantity at this point
Exclamation Where does the.......?
Hey.....I wanna install the air/fuel gauge......I read the DIY about it but I was wondering where does the gauge gets the information from???? the O2 sensor? what happen when you got afterma.. headers and the engine light its on.....or if you r using O2 sim????????
Old Feb 10, 2005
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
Some people have a bung welded to the header so that they can install a sensor for the a/f gauge. At least that's what a friend did with his WRX.
Old Feb 10, 2005
scatman's Avatar
Still in the game...
you can do splice into the wire that goes into your ecu that takes the signal from the o2 sensor. you just need to find out which wire it is.
or make ur own o2 sim for 5 bux....(should be the same size, this was done on a 03 Si)
Link
Old Feb 10, 2005
OK.....so, that means that the air/fuel gauge gets the info from te O2 sensor, right?......does it matter if u have a sim or the engine light on????? will the readings of the gauge be correct?...
Old Feb 10, 2005
TeLLy's Avatar
Yes, it's an Acura EL
If you have a sim, which by its design replicates a voltage corresponding to an ideal air/fuel mixture, then your gauge is useless if you tap to those wires.
Old Feb 10, 2005
ok thanks.........one more question.........will the vafc will show u the air/fuel ratio or u can only adjust it?
