key fob
Old Jan 6, 2005
michael815's Avatar
michael815 is an unknown quantity at this point
key fob
I think that is what it's called the thing that locks & unlocks the doors
On my 98 ex I have It so the horn beeps when you hit it.
But my son who has it now does not want it to.
But we can't figure out how to turn the beep off.
Any help?
Old Jan 6, 2005
shmik1's Avatar
maybe if you found a wiring diagram for it, but i'd have no clue where to look, see if you can find it on a OEM honda parts website, or any honda site that might have installation instructions you should be able to figure it out from there.. but Im not even sure i've seen it, I've seen instructions for installing fogs/oem lip kits and such tho..
Old Jan 6, 2005
shmik1's Avatar
I doubt it, but maybe u could ask a dealer for a set of instructions..
Old Jan 6, 2005
michael815's Avatar
No guys it has to do with the buttons on the thing, if you press in some order it stops the beeping, I just don't remember what buttons
Old Jan 6, 2005
shmik1's Avatar
oh i thought u meant to re-wire it and take the relay off that makes it honk..
Old Jan 7, 2005
profuse007's Avatar
Senior Member
profuse007 is an unknown quantity at this point
try holding down panic and unlock or panic and lock.... or anyother combination to disable /activate it, i cant remember exactly
if theres like a fourth button, option orsomething.... press that w/ unlock or lock
Old Jan 7, 2005
R1Style's Avatar
Push the lock button once... then it won't honk.
I know on my remote... I push lock once... it locks all the door silently but the lights flash. If I press it twice in a row... it'll honk and the lights will flash again.
Old Jan 7, 2005
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
1. Take off the front bumper
2. Find the horn (2 maybe or just one?? i forget)
3. Find the wire that leads from the horn to the Alarm CPU
4. Cut the friggin wire
5. Go to best buy/circuit city.. buy an alarm siren... just the siren.
6. Bolt it under your hood somewhere and wire it up.
a. One wire to power (battery or main fuse need constant power)
b. One wire to the wire you cut.
c. Ground wire
7. Now you have a cool "Doop Doop" instead the gay horn.
If you don't want the Doop Doop then just stop after step 4.
Old Jan 7, 2005
profuse007's Avatar
Senior Member
this is not a good idea. the horn trgger from the alarm CPU is a low current ouput. it used factory low current trgger swtich, usually from a relay. so the the alarm wire from the alrm unti straight to the horn wont exist.
c. Ground wire
Old Jan 7, 2005
michael815's Avatar
Thanks for all the reply's but we found the combo that turns off the horn & still locks the doors.
You have to have the car unlocked then hold down the option & lock button till the little light flashes three times.
Old Jan 7, 2005
profuse007's Avatar
Senior Member
see that, i remember something like that. gotta be persistence sometime.
good job dude.
Old Jan 8, 2005
4jacks's Avatar
Ahhh Welll... The darn factory models are always wired all complicated.. My aftermarket was easy
Old Jan 16, 2005
HappyGilmore's Avatar
HappyGilmore is an unknown quantity at this point
I tried doing this combo but can't turn off the horn. What is the correct step by step?
Old Jan 16, 2005
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
I remember theres a way to disable it, your right some how with the remote, did it on the 1.7EL when we got it back in the day. Check your manual
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
MamaBear2015
Sep 24, 2015 11:34 AM
meicalnissyen
Sep 22, 2015 06:20 PM
Klame9420
Sep 7, 2015 10:03 PM
