Jerking/Sputtering
Old Nov 20, 2004
civicsound0844's Avatar
civicsound0844 is an unknown quantity at this point
Jerking/Sputtering
Hey my car is jerking and kinda sorta sputtering at the top end of each gear. Around 4500 RPMs it starts to jerk alittle. And from there it just gets worse. Anyone have any ideas about what it could be?
Old Nov 20, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
What is modified?
Old Nov 20, 2004
Completly stock for now.
Old Nov 20, 2004
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
bring it back to honda, and let them take a look at it..
and for performance waise did you lose any ? it could be one of the cylinder fried.
Old Nov 20, 2004
Pull the ECU fuse for 10 seconds. Then put it back, start the car and let it sit and idle for about 10 minutes. Go drive it and see if it still does it.
Old Nov 20, 2004
Spark plugs, or maybe a broken engine mount?
Old Nov 20, 2004
I can feel it drop in performance once i get in the higher RPMs. The jerking comes from the power going and coming. Is that a bad sign?
Old Nov 20, 2004
Yes generally. Reset the ECU first, and then we'll go from there.
Old Nov 21, 2004
just reset the ECU and now it idles at 500RPM instead of 1000RPM does that make any difference? I am about to go drive it and see if it is any better. Wish me luck! Post once I get back.
Old Nov 21, 2004
Resetting the ecu is only to set the idle control. I hope you let the car sit for 5 mins without pressing the gas or using accessories once you pulled the fuse.
Old Nov 21, 2004
Got Boost???'s Avatar
could be the fuel pump, I have a fuel pump go out on me in my '01 EX and it would jer and sputter......then kill. And of course Honda blamed it on my header.
Old Nov 21, 2004
Resetting the ECU also clears the fuel trims.
Old Nov 24, 2004
I think I am just going to wait till I get back from Iraq and just put a RSX type s engine in. Thanks for all the help!
