Someone explain why we need coolant circulating the throttlebody.
Old Aug 31, 2004
redvtec04's Avatar
VTEC MASTER
redvtec04 should not be trustedredvtec04 should not be trusted
Lets see...when the engine is cold durring winter months theres no fluid flowing anyway. When the engine heats up residual heat is transfered to it anyway. So basically the coolant is flowing when the car is allready warmed up which makes no sense. So if you did the bypass mod then theres no r4ason to reverse it durring the cold months.
Old Aug 31, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Oil stays liquid to -60F, antifreeze about -35 to -40. So fluid still flows, otherwise your engine would run dry and burn up in no time.
Just keep telling yourself that you don't need the warm coolant in the throttle body, all the way until you're sucking in moist sub-freezing air and your throttle body freezes, locking the butterfly open.
Old Aug 31, 2004
gotti's Avatar
^ pwn't
Old Aug 31, 2004
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
^ yep!
Good explanation.
In real hot climates, you can do without the TB heater. But honda builds cars to be sold anywhere. So there ya go.
Old Aug 31, 2004
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
I've had the mod done since my car was new with no problems. I'd rather have my throttle unheated so that the air going in my engine is colder and denser.
Old Sep 2, 2004
jgoodfella1's Avatar
jgoodfella1 is an unknown quantity at this point
I have that mod done also. But believe this, If I moved to a cold climate I would switch it back in a heartbeat.
Old Sep 2, 2004
opto_isolator's Avatar
You guys are great - I love peoples logic on this board / intarweb....
The freakin' coolant runs up to the throttle body for the IACV (Idle Air Control Valve) - this valve determines the idle of the car, its in the Helms Manual, its on numerous web sites - READ AND LEARN! Doing the "bypass" **** can fvck up your idle. IT HAS NOTHING TO DO WITH VAPOR LOCK OR COLD INTAKE CHARGE TEMPS!
Old Sep 2, 2004
Agent9's Avatar
Agent9 should not be trusted
wow, so then it must all be in my head (no I'm not trying to be a smartass). But I could of sworn my car has a little more pep when I blip the gas now.
solarpunk70
Apr 12, 2016 11:43 AM
cferry7
Oct 3, 2015 04:33 PM
raymondxcho
Sep 29, 2015 09:00 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
