Intake Air Filter?
Old Jun 8, 2004
civicfreak84's Avatar
civicfreak84 is an unknown quantity at this point
Intake Air Filter?
Hey. Does anyone know how to clean the intake air filter on your aftermarket intake? I have heard about oillig? Washing? What is oilling anyways?
Thanks
Old Jun 8, 2004
civicvtec1ps's Avatar
Search and Learn
Go buy K&N Filter Cleaner.
Remove the Air Filter
Vacuum the filter well to remove any excess dirt
Apply a good amount of K&N cleaning solution to the filter
Let the cleaning solution set in for 10 minutes
Hose off the filter with water until no cleaner remains
Let filter air dry for at least an hour, and do not use an air compressor to accelerate the drying process
Apply the K&N oil to the filter, so that the filter material returns to a dark pink color
Touch up any un-oiled spots after a couple minutes
Let the filter dry for at least 20 minutes
Reinstall the filter
Old Jun 8, 2004
wow. thanks man! you are awesome!
Is there any place online that I can get the K&N Filter cleaner?
Old Jun 8, 2004
Buy from any store for $10.
Old Jun 8, 2004
NaHoOnEyYa's Avatar
NaHoOnEyYa is an unknown quantity at this point
does cleaning the filter make a big diffrence? and is there a online store where i can buy it at?
Old Jun 8, 2004
02 silver si's Avatar
02 silver si is an unknown quantity at this point
Auto Zone has the K&N kits if you have one by you.
Old Jun 14, 2004
ctx66's Avatar
ctx66 will become famous soon enoughctx66 will become famous soon enough
after the k&n cleaning solution is applied to the filter and your going to rinse it, make sure your rinsing from the inside of the filter out, at least for one full rotation. otherwise you will be pushing dirt into the gauze filter element
Old Jun 14, 2004
I just cleaned my AEM one this weekend and I found out after you soak it in the soap for 10 min take the water to the inside of it and rinse it till the water goes clear. That will make sure you have all the red die out of the filter. Took about 2 turns for me.
vtecbrah
May 12, 2015 01:30 PM
carid
Apr 30, 2015 07:00 AM
Hobby2K
Bolt-on Engine Performance
Nov 9, 2001 04:08 PM
