How to disable VTEC kick-in ALLTIME to save gas
Old Apr 19, 2004
  #31
truehonda's Avatar
truehonda has a spectacular aura abouttruehonda has a spectacular aura about
get a VAFC II and raise your vtec setting to 6 grand, hahhaha
Old Apr 19, 2004
  #32
JX6's Avatar
JX6
Redline Adrenaline VP
JX6 has a spectacular aura aboutJX6 has a spectacular aura about
Originally posted by Boilermaker1
Won't the engine starve like a ****? I mean... the whole point of high lift is to make the low lift low enough to make the low end effecient. Then you make the high lift so enough air gets in to make the car run better at higher RPMs. The low lift is lower than the A1 head, and the high lift is obviously higher.
I drive almost all highway miles... the car gets 39 to the gallon, how much better could you possibly get?
I don't see this doing much more than pissing the engine off.
I agree.
Also, Civics can burn "the cheap stuff" so thats what I buy to save money.
Old Apr 19, 2004
  #33
rockhound124's Avatar
rockhound124 is an unknown quantity at this point
VTEC = variable valve timing and lift electronic control
Old Apr 19, 2004
  #34
I got a hyper voltage system and raised my mpg to almost 34. That's 4mpg more than before with 90% highway miles.
Old Apr 19, 2004
  #35
Ichiban's Avatar
Ichiban is an unknown quantity at this point
Not to be mean or anything. But a few weeks ago there was a post on The 7th gen VTEC system. The 7th gen EXs have the VTEC-E system. The HXs have VTEC-E lean burn. The change over comes in at 2500 RPMs. If you have an intake and exhuast and you listen carefully you can kinda hear the switch. The whole point of the VTEC systems in these cars is to save gas. If you are cruising at 70 mph you will be in "VTEC" range. That, I found out is part of the reason why the VAFC won't work. And also I did disconnect the VTEC silonoid once and the CEL did come one. I just wanted to see what would happen. The acceleration sucked *** in first gear and in second gear the engine cut out at 4000RPMs.
Old Apr 20, 2004
  #36
Green Civic's Avatar
I get around 37-38 on 89 octane gas from walmart. Sometimes get on it and sometimes I dont. Just like boilermaker said, dont messwith the computer unless you want the computer to mess with you. I believe honda goes out on the road to test gas milage. The wind tunnel is to test the aerodynamics of the car. Not the gas milage.
Old Aug 26, 2005
  #37
Valdeezy's Avatar
Valdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to allValdeezy is a name known to all
I have a vfacII and I have my engaement point set to 2400 and I'm getting better gas mileage than before. The VTEC actually helps save gas.
Old Aug 26, 2005
  #38
MagicRacing18's Avatar
MagicRacing18 will become famous soon enoughMagicRacing18 will become famous soon enough
When I shift before 3500 I get 40MPG mostly highway some city. Once I kept it under 3000 RPM and got 43MPG. Its just how you drive.
~n~
Old Aug 26, 2005
  #39
streetglower's Avatar
this thread is too old to be bringing back to life.
wootah88
Jul 21, 2015 10:22 AM
Trennytrent
Jul 10, 2015 09:01 PM
jody501
Jul 10, 2015 11:01 AM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
cgavin1
Jul 7, 2015 07:10 AM
