V-AFC2 problem!
Old Apr 14, 2004
pnoyster2k1cvic's Avatar
Balut Eating Champ
Unhappy V-AFC2 problem!
I know there's a ton of post about VAFC2 troubleshooting, I checked them out but the CEL still comes on:
I connected the VTM according to CarbonFly vafc complete fix
http://www.7thgencivic.com/forums/sh...hreadid=132810
I also tried setting my H-L and L-H to within 200 of its cutoff
http://www.7thgencivic.com/forums/sh...hreadid=128671
And I used these settings: L>>>H--4500H>>>L4200 I also tried L>>>H 5200 L>>>H 5000 but the CEL still on!
http://www.7thgencivic.com/forums/sh...ighlight=vafc2
What could be the problem? I couldn't pass over 4000 rpm! and CEL is on! I think the settings are wrong, Please help! thanks!
Old Apr 14, 2004
First off, make sure all the wires are connected properly (a couple aren't used).
I would just leave the vtec points stock. Anything else will lose hp.
Lastly, did you perform the initial setup BEFORE starting the car for the first time? I'm guessing you didn't, and there's your problem. Go unplug the battery and start over, this time reading the manual.
oh and btw, vtec=3 for our cars.
Old Apr 14, 2004
Balut Eating Champ
damn it! that could be it! I did the initial set up but! I put set the vtec 1 :P thanks bro! I'm gonna try again tomorrow!
Old Apr 14, 2004
To change it to three, you can just turn the car to on (don't start it) and set the value. Then turn the car back off. After that, it should be saved and you can start it up. No need to disconnect the battery.
Old Apr 14, 2004
CarbonFly's Avatar
My vtec is set at 1, and I don't have a CEL problem. But I did go through the rest of the setup also before I started up my car.
Old Apr 14, 2004
Balut Eating Champ
On my V/T cont: I'm using Lo>>>Hi---4500 and Hi>>>Lo---4200
What you guys got on your settings?
Old Apr 14, 2004
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
I have mine set to passive aka stock, since this was the best setting the dyno tuners found for the most HP gains/pull for my setup anyways. All I remember was that changing it more than stock lots of torque was lost and below stock engine was somewhat unstable. Be sure to get it dyno tuned for the best gains, since they'll know what your a/f ratios should be at each point.
Old Apr 14, 2004
Balut Eating Champ
Yeah I'll get it dynoed either today or tomorrow if I can get past 4000rpm, I got everything set right but the CEL is on and I can't get past 4000rpm, I'll put mine on stock also lets see if that one works, that should look like **** right? okay! I'll triple check...
but did you guys put a diode?on the pink and purple wire? the diagram on the manual didn't mention anything but based on the DIY on this site:
http://www.7thgencivic.com/modules.p...howpage&pid=58
On DIY #1 says two DIODES
On DIY #2 says only one DIODE
I followed DIY#1 putting two diodes in pink and purple wire
What is it really? the diagram on the manual didn't mention anything about a diode, did you guys put a diode? if so, which wire? can you tell me all the details please! thanks!
Old Apr 14, 2004
NorrinRadd's Avatar
Diodes? If you have the VAFC2, there is no need for diodes, diodes were needed for og VAFC and not the VAFC2. Those diodes may be causing your cel. You just need to follow the VAFC2 instructions it came with and connect the VTM wire and you should be good to go. Again, no diodes. Good luck...
Old Apr 14, 2004
djmota's Avatar
there is no diode used on the vafc2 it works fine without any need to do anything special but hook up the vtm wire. the one that needs to be fixed is the original vafc.
Did you solder all connections? I hope so. double check all connections and do the initial set up again. make sure you read the instructions while you do it so it is right. Leave the vtec engagement on passive also. this has been proven time and time again to be the best setting.
Old Apr 14, 2004
Balut Eating Champ
wooooooooohoooooooooooooo got it workin! it was that damn DIODE!!! thanks you guys! appreciate it much!
check it out!
http://www.7thgencivic.com/forums/sh...hreadid=149874
Old Apr 14, 2004
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
I also found out that the car is unstable if you change stock vtec settings.
Someone needs to do a DIY and tell all to leave it in passive mode. I dyno'd mine and it was all over the place when I took it out of passive mode. Also if iset the vtec mode to 3, I get check engine light. My car is set to 1. Anyone else experience this?
Good luck all.
Old Apr 14, 2004
Balut Eating Champ
I got my vtec set on 3, and my vtec set to Hi>>>Lo 3400 and Lo>>>Hi 3000 but the vtec kicks in on 5200rpm? anyway its kinda kool having that kicking in on that level!
Old Apr 21, 2004
FuzzBeC00L's Avatar
Fuzzy Boy
Whats the initial setup I did not do that and my cell is not on..This guy said the setup is over for i-vtec or sumthing
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
