CEL, I know the code, what to fix?
Old Mar 31, 2004
  #31
civicstreetrcr's Avatar
civicstreetrcr is an unknown quantity at this point
Yes you have to relocate the sensor or else the ECU will not know theres a cat
Old Mar 31, 2004
  #32
OsOBooSTeD's Avatar
OsOBaNNeD
i have no cat and no cel .. then explain that?
Old Mar 31, 2004
  #33
guns's Avatar
Skyline R33
guns is an unknown quantity at this point
IF your MAP sensor sees any boost or anything above 0psi you will get misfire on all. I had that happen alot with my check valve setup. I switch to missinglink and the problem was solved. I would bet its your check valve. Go with the missinglink or add another checkvalve to your map sensor and see if the problem goes away.
jbradley4809
Apr 7, 2017 04:23 AM
juror
May 26, 2015 06:35 PM
rcolosi
Apr 29, 2015 07:48 PM
Fastfebur
Apr 26, 2015 11:57 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
