!!!o2 simulator question!!!
Si(R) killer # 1
Originally posted by WannaBFast
i was just stating that the first o2 sensor failure would put your car into limp mode cause it adjusts the air/fuel mix, the second o2 sensor just determines if the cat is functioning properly or not
if the second o2 sensor isnt reading properly, it wont affect anything performance wise, it will just have the check engine light on and that is all
Now if you just unplug the second 02 sensor will the car just throw the light? Or should I just plug it in and tie it up to something so the car thinks it might just be malfunctioning? Thanks
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
02, 2004, bigjoshracingcom, car, civic, customized, downstream, eliminator, honda, logs, mess, o2, simulator, wire, yahoo
