VAFC II problem has been solved!!!!
Old Dec 7, 2003
CarbonFly's Avatar
As some of you know, I had a problem with my CEL and not being able to rev over 4000 RPM.
With the help from BLCKOUT's friend(Chris), the problem has been solved.
Your VTEC engagement setting has to be within 200rpm of it's cutoff.
Example
L+H = 5200
H+L = 5000 or 5100
If the difference is greater than 200 then the ECU thinks that something is wrong.
Old Dec 7, 2003
BLCKOUT's Avatar
BLCKOUT is an unknown quantity at this point
Re: VAFC II problem has been solved!!!!
Example
L+H = 5200
H+L = 5000 or 5100
Hey i helped to! i asked him about it for ya!! gimme the credit i deserve!!!!
Old Dec 7, 2003
DogstyleEX's Avatar
DogstyleEX is an unknown quantity at this point
hell ****ing yeah donkey..
Old Dec 7, 2003
Glad this got figured out.
Old Dec 7, 2003
audioefx3's Avatar
audioefx3 is an unknown quantity at this point
sweet So when does vtec engage for you now?
Old Dec 7, 2003
DogstyleEX's Avatar
yeah.. that's one thing, how does changing vtec engagement to a higher rpm make us quicker?
Old Dec 7, 2003
cdmx's Avatar
I remember reading this stuff about the vtec engagement months ago, this is old stuff.
And when did you get a VAFC2 fly???
Old Dec 7, 2003
Samari's Avatar
yea, wouldnt making the vtec engage at 4k instead of 5k be better?
Old Dec 8, 2003
CarbonFly's Avatar
Here is pics of my install........
http://www.7thgencivic.com/forums/sh...hreadid=128506
I have my engagement point set at 5400rpm.
Old Dec 8, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
The new VAFC II has a new vtec passive feature that allows the ECU to decide when the vtec output engagement to turn on...The guy that tuned my car said that this is the best setting because it builds power through the whole power band...Currently the VAFC vtec engages when the stock vtec engages around 2500-3000rpm...Although you can't feel the "jolt" when setting it high, the car seems to pull alot harder even with the problem that I'm having with the KMS manifold
The first VAFC didn't have this feature so you had to settle for setting the engagement higher , which really dosen't help our cars due to the new vtec engagement coming on so low in the RPM range..
Old Dec 8, 2003
CarbonFly's Avatar
Yea, I just decided to change it to your setting cwick. I can still feel the kick too.
Old Dec 8, 2003
cwick187's Avatar
It pulls a little harder dosen't it?
Old Dec 8, 2003
CarbonFly's Avatar
Yea, but i don't feel as much of a kick, but the kick is still there.
Old Dec 8, 2003
cwick187's Avatar
Yeah, the "kick" is fun for awhile...but from a performance stand point, your better off with how you have it set now.
Old Dec 8, 2003
NeonImpact's Avatar
Forum Sponsor
would that cause problems in the long run?
Old Dec 8, 2003
NorrinRadd's Avatar
NorrinRadd is an unknown quantity at this point
Cool, glad this has been solved, changed my engagement to 5400 too. Yup, pulls more, but smoothly w/ a slight kick. Nice though! I'm not sure, but please correct me if I'm wrong... Couldn't we somehow use the VTEC Unmatch feature on the V-AFC II to allow us to use a wider VTEC engagement range? I thought I read in the manual, that you use this feature when you change VTEC engagement from stock settings in order to adjust fuel delivery, since the ECU doesn't see the change and still sends extra fuel at the old setting. I was gonna play around with this, until I saw your thread Fly. Thanks for finding a fix so quickly FLy Kinda sucked when I installed my V-AFC II last Friday only to find my cel coming on the next day.
Old Dec 8, 2003
R3DL1N3's Avatar
hey cwick would you pm me your vafc2 settings and the diagram you used?
Old Dec 8, 2003
cwick187's Avatar
Dude, there is alot more than just a couple of settings to the new VAFC...It has alot more tuning features than the first one...You really need to have it dyno tuned....I'm not trying to be an ***, but I couldn't begin to tell you what the settings are...As for the diagram: I think it's H-8..Is that right Fly?
Old Dec 8, 2003
NorrinRadd's Avatar
Why not, they're all stored on the V-AFC II. Couldn't you just PM me and R3DL1N3 them anyways. You don't have to explain them just list them out. How about you Fly, would you be Ok with PM'ing me and R3DL1N3 your V-AFC II settings, thanks. I don't care if our setups are different, just want a baseline to work from.
Old Dec 8, 2003
cwick187's Avatar
The settings that come the VAFC are baseline.So, what exactly are you wanting??? My tuned settings?
Old Dec 8, 2003
NorrinRadd's Avatar
Yes, if it's ok w/ you, otherwise that's cool. I have similar perf mods (minus KMS manifold), so I thought you're settings would be a good start.
Old Dec 8, 2003
cwick187's Avatar
I might be able to get them to you sometime at the end of the week...i have final exams this week...
Old Dec 8, 2003
NorrinRadd's Avatar
Cool, that would be great, thanks so much.
Old Dec 9, 2003
cwick187's Avatar
You should wait until I put my stock manifold backon and have it tuned so it would be closer to your setup...I'll see if i can get it to you guys as soon as i can
Old Dec 9, 2003
CarbonFly's Avatar
You're a better man than me cwick, if I paid the money you were paying for tuning, I would keep those numbers to myself.
Old Dec 9, 2003
cwick187's Avatar
It won't really benefit anyone else anyways...Each car is different and each mod is different as well...It's kinda useless for them
Old Dec 9, 2003
SuperSajin's Avatar
SuperSajin is an unknown quantity at this point
How much extra hp does this give you? i've heard 10-20
Old Dec 9, 2003
civicskater's Avatar
Chicks dig my scent
Wow, awesome...i know LX dosent have VTEC, but...i've heard you can still use the VAFC II but not plug in the vtec wires and use those setting? This true? Would i benefit from it, or is it a waste of money?
Old Dec 9, 2003
ImportRacer2123's Avatar
K20 Member
fly what exactly is your engangement point? I need to know what the lowest i can have my VTEC at because i am having the 4000 RPM Level.
Old Dec 11, 2003
K20 Member
Fly please help me
