fogged
Old Nov 30, 2003
samscivic's Avatar
samscivic is an unknown quantity at this point
fogged
hmm i dunno where to post this so ill put it here, well my problem is that my right tyc headlight is starting to fog up just recently, and i dont know why? i had it for around 1yr. ill put pics of what it looks like tomorow durrn the day. but anyways what should i do? is it really a big problem/ if there is a hole that water is getting in, is it hard to find a patch? thanks
sam
Old Nov 30, 2003
ImPulse's Avatar
Well, with aftermarket headlights you are @ a 60% chance of them getting some moisture in em... I would take both of them off.
First: Take a blowdryer and put it on warm and put the warm air through the back of the housing so that the air is getting it. Then see if the moisture goes away.
Sometimes the moisture MAY leave marks... (water marks) If you get them and are unhappy, then you have to put your tycs in the oven @ 330 degrees for 8 minutes, unclip it and take it apart, then clean em, and put them back together.
If there are no watermarks, then take some waterproof silicone and put 2 layers around the part where the 2 pieces of the housings meet. (So that water cannot get it). Put 1 layer around it, wait like 30-40 minutes, and put another layer on it.
Silicone takes 24 hours to fully cure but, you can still put the projectors on your car like 2 hours later (just make sure it isnt sticky).
Hopefully that helped (:
Old Nov 30, 2003
samscivic's Avatar
thanks ill try that!
UltraHDGames
Jun 8, 2016 05:16 PM
mrwhos
Aug 11, 2015 02:03 AM
j-chest
Jul 31, 2015 01:18 PM
Enigma346
Lighting
Jul 12, 2015 08:24 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
