alternating lights?
Old Nov 12, 2003
jackscivic's Avatar
jackscivic will become famous soon enough
alternating lights?
ok i was wondering if anyone knew how to make lights alternate. like how on some cars the sidemarker and turn signal alternate when it is on. i want to apply this to either neons or my turn signals. could anyone shead some light in this?
Old Nov 12, 2003
Hey man. Check out my sidemarker DIY in the tech forum. I just found out how to do this. If parking lights are on, sidemarker stays on. If only signal is flashing, sidemarker will flash in sequence with it. If parking lights AND signal come on, the sidemarker blinks out of sequence. Inanimatecarbonrod has a DIY as well, but my way only involves tapping two wires.
Old Nov 12, 2003
jackscivic's Avatar
thanks this helps alot. what i want to do is make a halo slightly larger than my 7440 bulb in my rear turn signals and make it into there so that when i put my turn signal on it will flash from the halo to the bulb ( maybe put a led bulb in). i think it would be original and look pretty cool. anymore input would be good
Old Nov 12, 2003
To get the effects above, you need to tap a parking light wire and the turn signal wire. You would only get the alternate effect when the parking lights are on AND you use the signal.
Old Nov 12, 2003
vietstylez's Avatar
flashing halo blinker?? ewwwwww
Old Nov 12, 2003
jackscivic's Avatar
hey its a four door! and its only an idea, who knows it may be pretty good! i ahve plenty of time to try it so who knows!
thanks gearbox. so are you sayin tap the rear parking light and tap the turnsignal? the thing is that i only have a positive and negative wire. does this require a relay or anything like that?
Old Nov 12, 2003
Nope. You are tapping two positive leads. One to park and one to signal. That's all. When the park lights are on, the signal wire acts as a ground and vice versa. That also creates the alternate effect when park lights and signal are on together. When signal comes on, it blocks the ground. When it blinks off, they come on again.
Old Nov 13, 2003
FattyMcJ's Avatar
Addicted to the Twisties!
Hmmm...that would be cool to do on the front end. Have a side marker on the front bumper...alternating with the turn signal. I might try that!!
Old Nov 13, 2003
It looks better than I thought, and it only does it when the lights and signal are on together. I saw another car that had them like this.
HiImBrandon
Jun 1, 2015 07:34 AM
MiniMi
May 27, 2015 01:57 PM
davidarenberg
May 16, 2015 08:45 AM
Tarbris
Electrical
May 3, 2015 09:51 PM
smmahan
Apr 15, 2015 08:17 PM
