Fixed the play in my revo SS
Old Oct 19, 2003
Drnknmnky13's Avatar
Not sure if anyone else has any side to side play in thier revo SS but it was bugging me to no end. So last night I took it apart and figured out why. See that gap? I had to push my shifter that far before the ap was taken up. I busted out my trusty set of files and filed down the stop for the spring. There is no more gap, so there is no more play. Hopefully no one else experienced this problem. But if so I hope this helps.
Old Oct 19, 2003
vietstylez's Avatar
yes..the play annoys the crap out of me! everytime its in gear i wiggle it around an im like wtf whyyy. i'm going to have to try that...thanks!
Old Oct 19, 2003
CapYoda's Avatar
Escaped Convict
beside that part, there's another part that can use some more work.. the joint down below...
the stock spring is also stronger... but its not easy to swap into.
Old Oct 19, 2003
Well the actual part that I filed down is below that pic. There is a stop about an inch lower. I couldn't get a good picture of it but figured people would see it when they pulled the shifter out. It didn't fix the problem 100% but about 95%.
Old Oct 19, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
are a lot of people having these problems? Also, do you have either the Grey or CapYoda's shifter kits? I think those are meant to fix that.
Old Oct 19, 2003
cdmx's Avatar
Can you or did you take pic of the place where you filed it down.
Old Oct 19, 2003
cdmx's Avatar
I dont have a revo but me i probably wouldve put some sort of rubber "bushing" around that metal piece to stop the movement.
Old Oct 19, 2003
CapYoda's Avatar
Escaped Convict
ah our kits dont fix that...
grey's kit fix play but not play from that location.. mine fix assembly to chassis play...
Old Oct 20, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
Yeah, I have that same problem, but it's like a 35 minute job to get my shift *** back on properly so... Untill I wanna swap it out, I'm just gonna forget about it. I have a collar with a set screw below my shift ***, this is what holds my boot up, unfortinutly it's almost impossible to get right and takes forever to tighten down.
Old Oct 20, 2003
jwalker87's Avatar
Bodacious Member
CapYoda, I ordered your kit, yet have received no acknowledgement. Did you get it?
Old Oct 20, 2003
I have both Grey'ss and Capyoda's Kit. Capyoda's is good if you shift hard. I don't shift that hard so I don't nitice a differnce. Grey's kit helped the frant to back play but not the side to side. Considering the price they offer thier kits for though..I would recomend ordering them. (not to mention your helping members who usually give helpfull info).
On another note..Cap and Grey...how about an upgrade for the seat bushings so I don't have to take my car into the shop every 2 months to get them replaced
Old Oct 20, 2003
4bangin's Avatar
cap and grey's kits are the shizzle for rizzle yo. i love em. but ya the side to side play is kinda annoying. i have mastered getting all that **** apart so maybe i will have to take a look at that.
Old Oct 20, 2003
The piece is supposed to move. thats why there is play. The problem is that there is a gap between when the stick moves and the spring moves and provides resistance. I thought about sticking something in the gap but it was easier to file down the stop. Also I didn't want whatever I placed in the gap to come out. Sorry I didn't get better pics of the place I filed down. But if you take it apart you'll see exactly where I am talking about. It's directly under the gap about an inch down. by filing down you allow the spring to touch the plastic at it's start. Hope I helped more than confused
Also as Cap explained..if you want to take the time to replace the spring...it would help tremendously. It would also give the shifter a nice tighter feel.
Old Oct 20, 2003
skipbarber's Avatar
cap's bushings were my first mod
i was kind of skeptical at first, but when i installed them i was like
Old Oct 20, 2003
exedotbat's Avatar
exedotbat is an unknown quantity at this point
can you post another pic just not so close, i cant tell what im looking at. Thanks
Old Oct 21, 2003
You should be able to figure it out from this pic. I marked where you need to file to get the gap out. Let me know if anyone needs more or better pics.
Old Oct 21, 2003
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
Could you file it down while it was installed? I hate to take my Revo totally out again, since I was just in there....
Old Oct 21, 2003
I guess you could. I took it all the way off cause I wasn't sure what was causing it at first. Of course you could just live with the play...I mean it's not THAT bad. I wanted to find a way to reinforce the plastic where the spring meets it...I thing it has worn away with use. I was thinking of cutting and super glueing a rubber band piece in there. or even cutting a small washer in half and mounting it.
Old Oct 22, 2003
Grey's Avatar
DIY King
Hmm... I kinda understand why there's side-to-side play now. My SS Upgrade Kit does take care of some of the side-to-side play though. I might include something to take care of all of the play in the SS. Stay tuned...
As for the seat bushings... This is an EX problem I think, right? It has to do with the seat height adjustment. I don't have an EX, so I can't tinker with it.
Old Oct 23, 2003
I have your upgrade. It helps tremendously with front to back play. And would help if the play was in the cable. But the play is in the shifter itself. Unless without your kit the play is worse..that would suck.
I keep asking for the old bushing when I get mine replaced but they always "forget" I keep waiting for them to tell me " dude...the car is designed for 150 pound asian guys"
Also a quick word of advice..if you take your shifter apart to do this...regrease everything. I noticed a huge improvement. I guess the grease dries up.
Old Oct 23, 2003
CivicRookie's Avatar
Jeremy's Iron
CivicRookie is an unknown quantity at this point
What sort of grease?
Old Oct 23, 2003
jwalker87's Avatar
Bodacious Member
the greasy kind
and yes, i am a post *****
Old Oct 24, 2003
Crisco works the best. But olive oil is less fattening for you car. Less wieght = faster.
Just playin. Regular grease you get from autozone. I use the white grease. Better grease would last longer. Mine lasted a year before I regreased. I only used a tiny bit last time...this time I applied a good amount. Should be a long time till I need to regrease.
Old Oct 31, 2003
SMURF_KILLER's Avatar
SMURF_KILLER is an unknown quantity at this point
cool things to keep in mind when I get my kit
Old Nov 8, 2003
pheaton's Avatar
A descendant of 2k1civic.com
HAVE no fear pheaton is here!!! Ok guys. . here is a pic that will help you see it a little bit better. Instructions are as follows:
Before you begin, examine the assembly. Use the other posted pics to identify the area that we are talking about. I circled the area that needs a slight trim to get rid of any play. .
1. Pull the spring end toward you to pull it out of the slot and push the spring end to the right out of the way, so it's on the outside of it's resting spot circled in red.. (like shown in the picture). It should stay there by it self. .
If you have to, pull the shifting bar to the left, in the neutral position. This will make it easier to grab hold of the spring to move it out of the way.
2. Now, have at the lower slot. I used some needle nose plyers to grab hold of little chunks of plastic to tear it away and finished by sanding/smoothing it down with the fingernail file on a pair of nail clippers. Don't tear off more plastic than you need for the spring to lay flat and do your best to preserve the shape of the slot.
HOPE THIS HELPS!!
Old Nov 8, 2003
jwalker87's Avatar
Bodacious Member
wow! thanks. One small question though; roughly how much did you have to file away?
Old Nov 8, 2003
fuledya's Avatar
Super Member
why did you tear away wear the spring doesn't rest anymore? Im a little confused, but am interested in doing this. Can you give me just a little more explanation? BTW, great pic!
Old Nov 9, 2003
pheaton's Avatar
Very little has to be filed away. I just used some needle nose pliers and grabbed little peices of it. Just check it after you remove a little bit and keep doing that until you have it where you want it. But it's not much at all.
and fuledya. . I just moved the sping to the side so that it was out of the way, so that I could shave off some plastic. .
Old Nov 19, 2003
You need to file away however much gap you have. If you have .5 cm of gap..then file away .5cm of stop. the gap is pretty small..like seriously the distance between these two lines ||. Your could be a little less or a little more though. Hope this helps.
Old Apr 3, 2004
zen_master's Avatar
interesting!
