vinyl decal tips?
Old Oct 5, 2003
R3DL1N3's Avatar
vinyl decal tips?
ok is there a special way to put vinyl decals on? it seems like everytime when i peel the non sticky part off some of the letters or whatever dont go to the other side so the decal is ****ed up.
Old Oct 5, 2003
01WingsWestCivic's Avatar
7thgen Man-gina
01WingsWestCivic is an unknown quantity at this point
not understanding 100% what you mean in your post thats going wrong... however, the vinyl should have some transfer tape. youll want to clean the areas the decals are going and them put some soapy water on the area. the soapy water will allow you to move the decal into place after you put it on. when you get the decal where you want it, squeegie out the soapy water, you can use a library card for this. then just peel off the transfer tape
-joey
Old Oct 5, 2003
Mags's Avatar
will you make out with me
Mags is an unknown quantity at this point
advice: just don't do it
Old Oct 5, 2003
R3DL1N3's Avatar
what im saying is there a way to make the lettering transfer right? half the time i peel them they **** up. but i just want 2 small stickers on the top back and front middle windshield.
Old Oct 5, 2003
CivicHX01's Avatar
don't peel away from the window, peel parallel to the window...
Old Oct 6, 2003
Renamazazo's Avatar
Renamazazo is an unknown quantity at this point
instead of soapy water, use windex, it works like a charm. Also, use a firm card or something (like a library card as mentioned above) to get all that air and **** out of there. then let it sit for a little bit, then pull away very slowly.
Old Oct 6, 2003
bluestreak's Avatar
bluestreak is an unknown quantity at this point
if the decal isn't sticking to the transfer paper, rub the hell out of it before removing the backer......also try wetting the face of the decal first....
Old Oct 6, 2003
ShoelessEX's Avatar
The wheel is turning...but the hamster is dead
ShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to allShoelessEX is a name known to all
I totally agree!
SammySC
121
Apr 7, 2017 07:43 PM
carid
Sep 28, 2015 10:13 AM
General DIY
Sep 25, 2015 08:02 PM
emiixo
Exterior
Sep 22, 2015 03:53 AM
Bikergofast
Sep 12, 2015 10:54 AM
