timing belt?
Old Oct 1, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
timing belt?
ne one know how to tighten the timing belt? I know theres like a bolt u loosen , or a screw u turn thats connected to the spring that tensions it .. ne one know how to do it ? cause mines alil loose.. i wanna tighten it ? GREY? ne ideas?
Old Oct 2, 2003
djmota's Avatar
theres a bolt next to the auto tensioner that lets you adjust it, however that bolt (i think its an allen) is covered up along with the tensioner by the lower timing belt cover. You can not get that cover off without taking off the lower pulley and ps alt a/c belts.
If its loose from just driving you should have the belt and tensioner replaced, but if its loose because you where turning the motor backwards manually, then thats normall, and tunring the motor manually a few turns the right way will tighten it back up.
mattdoc
Mar 14, 2017 12:10 PM
EdGasket
May 25, 2015 01:06 PM
MN-02-CivicEx
28
May 2, 2015 09:11 PM
dano2005
Apr 14, 2015 01:58 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
