02 si axle question for swap
hey peeps just got a quick question...I read on hasport that the 94 and up integra gsr axles fits the k20A3 and i was just wondering if it is true? I don't want to buy really expensive axles from honda. Also does any one know of a performance axle for the k20A3? please help
No it's not true. I can't believe I haven't changed that yet. I'll try to take care of it Monday. The GSR axles almost work, the inner joint on the driver's-side axle is too short and doesn't fully engage the diferential.
Hasport sells upgraded axles for that application.
brian g
brian g
Its a celebration bitches!
the reason is if you wanna keep your 4 lug because the rsx tranny - axels on a si is 4 lug. and the rsx - civic is not compatible.
if you wer to do the 5 lug, you would just use all the rsx components
hey i have a good question for you guys
if i wanted to accomplish 500 hp and 500lb of trq with my civic with a k20 powerplant do u guys suggest i convert to 5 lug and use rsx axles,brakes, and disks or should i just stay with 4 lug and uprgrade to two piston calipers?
Originally posted by NoBottleJustThrottle
im using GSR axles now and they work just fine. You are talkin about a K20A3 though, it might be different than my K20A2.
4-lug: GS-R/Si front axles
5-lug: RSX front axles
I never knew Hasport sold front axles for engine swaps... hmmm....
brian g
Originally posted by briang
With 500 hp the stronger RSX axles would be a good idea.
brian g
brian g
You need to buy custom axles and a LSD and clutch to handle the hp and torque.
RSX axles are not designed to handle anything like that.
The driveshaft shop will make customs, I know up to 300-350 hp handling they are $700 USD
thanks for the feed back guys that really helped....Also, I got a friend who ownes a 02 civic si and he also needs new axles just to replace his stock , any ideas where to get them.
7thgensurvivor
38
Aug 29, 2015 11:50 AM
ClutchMasterOG
May 31, 2015 03:25 AM
mrohitredd
May 28, 2015 10:03 AM
