i need help bad
Old Sep 6, 2003
j-jolly's Avatar
j-jolly is an unknown quantity at this point
i need help bad
ko here is the deal. i blew my first engine so i thought why not get a vtec since i have to buy a new engine any way so i got my engine and i got an ecu and a wiring harness it gets all set up i plug the vtec ecu in the car turns over but does not start so i think ecu is busted i order another same thing so now i think it has to be somthing else the non vtec ecu runs in it but it hurts me by about 30hp the wiring harness that i orders was hacked up cause the guys i orderd it from were lazy and cut ends could that have somthing to do with it maybe a wire missing any help would be appreciated thanks
Old Sep 6, 2003
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
you need to use some periods lol. Confusing as hell.
Here's your DIY trouble shooting by me. Auto or Manual Transmission? Anyway:
If the non-VTEC ECU runs the engine, but the VTEC ECU doesn't... it can only be one of two things really. Because I would assume that using the VTEC and non-VTEC ECUs... you still used the same harness (which was for a VTEC I'd hope).
1. Somethings not right with the wiring
2. ECU sucks
I'll go with #1. So do this. There is an ECU wiring diagram in the DIY section. I labled almost all of the VTEC only wires. The others are obvious. ECU Wiring
Compare the ECU wiring and **** between non-VTEC and VTEC, and check the wires that are VTEC only and make sure they are correctly hooked up. Because if the non-VTEC ECU works... you already know that those wires are good.
Old Sep 6, 2003
clownprince's Avatar
Ricerus Maximus
If your old ECU will start it but the new one won't, it's probably a key malfunction. Remember that our keys have the anti-theft dissabler on them and it works in conjunction with the ECU. You will have to have the car taken to Honda and get the keys reprogrammed.
Old Sep 6, 2003
cryption's Avatar
2003 Nissan Frontier
it also could be your imoblizer
SimpleUser
Apr 24, 2021 02:54 AM
Green02civic
Jul 27, 2015 10:48 PM
cukaracha
30
Jul 26, 2015 12:01 PM
CivicsClass101
Jul 9, 2015 11:14 AM
Bounddyy
Jul 8, 2015 11:22 AM
